Old 03-28-2004, 02:55 PM   #1
280 td mileage
What kind of mileage are you getting on a 280 Diesel MH? Are these generally a reliable engine? Did AS use a different rear end ratio for the diesel? Thanks
moisheh is offline   Reply With Quote
Old 03-29-2004, 06:17 PM   #2
stuart2's Avatar
Hello!
I've got a 310 with an IsuzuTurbo Diesel and I get low 11's when I tow the toad and high 11's the rest of the time.
I've been told by most of the diesel mechanics I've talked with that the engine will out last the MH IF you respect the temperature limit of the turbo charger. I limit myself to 900 degrees even though the actual limit is 1100 degrees. Also they've stressed the importance of oil changes ever 3000 miles.
I feel comfortable with the engine but I will admit a little more power would be nice. I've never had her in the mountains but I'd guess she'd be a little under powered.
I don't know what the rear end ratio is but I'll do a little digging and find out.
Happy trails 2 U! Stuart
stuart2 is offline   Reply With Quote
Old 03-05-2008, 10:55 PM   #3
Hypnotist
jjhypnotist's Avatar
1982 28' Airstream 280
las vegas , Nevada
82 280 turbo diesel
when I got mine I was getting 13-14 mpg driving 65-70 miles an hour and the engine was screaming (No overdrive on the chevy 400 tranny)
I have since had the tranny rebuilt and installed a Gear Vendor OD unit and I am getting 15 + I have not towed my trailer behind it as of yet
Justin
jjhypnotist is offline   Reply With Quote
