Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 10-11-2003, 08:30 PM   #1
Jim Tyrney
Jim Tyrney's Avatar
Profile:
Question 1986 As 345 Mh
In my 345, it has the 1" wood slat blinds that have "LOOKOUTS" on the bottom with Elkhart, IN and Anahem, CA also. I am trying to find out where I can get wands, part that wand fits to and end caps for hold downs. Also, the window locks for the cab, any available for replacement? Still finding minor items to repair but having fun SO FAR!!!!! Thanks for any information that may be given.
Jim Tyrney is offline   Reply With Quote
Old 10-12-2003, 08:13 AM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Re: 1986 As 345 Mh
Originally posted by Jim Tyrney
...Also, the window locks for the cab, any available for replacement? .....
I bought one from an Airstream dealer and found that due to a wrong size spring used inside the lock, it would not function properly. (once locked, you could not depress it far enough to unlock it)
I had to take it apart and use the spring from my old lock. I do not know if the dealer forwarded my detailed description of the problem to Airstream.
Cost was around $110.-
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 10-16-2003, 11:48 AM   #3
Lido&Linda
Lido&Linda's Avatar
Profile:
I get my parts from Inland RV if they dont have it then AS dont stock it any more.I just did the sliding windows passenger and driver side, I replaced the fussy channel they have the right part from AS it cost like $2.65 per linear ft. The trim on the outside is also availble except for the piece that goes in to the pillar.
The Unleaded Zeppellin
Lido&Linda is offline   Reply With Quote
Old 10-16-2003, 12:01 PM   #4
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
peter
i payed jackson center $84 for replacement locks and as you related they dont work. i cant unlock them , i still have the old locks that wouldnt lock. i havent had much time to look at them but i need to get the drivers side fixed.
thnx al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB
wb13798 is offline   Reply With Quote
Old 10-16-2003, 12:15 PM   #5
PeterH-79MH
Profile:
Images: 63
Al,
If you have the old locks, take them apart and retrieve the old spring. More and likely what broke is the plastic of the locking mechanism.
The picture below shows the difference of the two springs. The shortness on the upper part of the new spring is the reason for the malfunctioning lock.
1986 AS MH 345 Air Suspension Jim Tyrney Airstream Motorhome Forums 2 01-05-2004 03:42 PM
1986 345 MH H2O Reel Jim Tyrney Airstream Motorhome Forums 2 10-21-2003 10:22 PM
1986 AS 345 MH H2O Check Valve Location Jim Tyrney Airstream Motorhome Forums 10 10-21-2003 08:47 PM
1986 AS 345 MH Magic Chef Shut off Valve? Jim Tyrney Stoves, Ovens & Microwaves 2 10-14-2003 02:48 PM
1986 As 345 Mh Jim Tyrney General Motorhome Topics 3 10-10-2003 07:15 PM
