Old 01-19-2015, 08:48 AM   #43
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
The 23' is the only Airstream that comes with 14" wheels -- because it is the smallest double-axle trailer it has the least weight per axle. Like mutcth, because we were not comfortable with either the wheel size of the Marathon tires, we upgraded to 15" Sendel wheels but went with Michelin P235/75-15XL LTX M/S2 tires. Better ride, and peace of mind.
field & stream is offline   Reply With Quote
Old 01-19-2015, 09:18 AM   #44
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Thanks for correcting the wheel size. I did not know that Airstream used a 14" wheel. We have been very pleased with the 16" upgrade to our Bambi and wanted to do the same to the 23FB. We used an American Outlaw II wheel for the Bambi. I see that American offers two 5-bolt sizes in a 16" x 8" wheel: 5x135.00 and 5x139.7, backspacing 4.5. any idea if either of these would work? It looks like there is clearance between the tires and the wheel well, though not sure about the width at the top.
I think we definitely want the 16" wheels due tot he choice of tires available and the availability of a load range E.
Steamy1 is offline   Reply With Quote
Old 01-19-2015, 09:30 AM   #45
2008 23' Safari SE
2007 Base Camp
Hi Steamy1 -- I can't answer the question about the wheel spec's, but perhaps contacting Airstream Customer Support at (877) 596-6505would be one good source. Also not sure about tire clearances, but the 15" combo does not leave a lot of room. Once again due to the low weight per axle, load range E tires may be overkill and load range D tires will give a better ride. I am far from being an expert, but hopefully these thoughts are helpful.
Old 01-19-2015, 10:07 AM   #46
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Steamy1:
I upsized our wheels from 14 to 15 inch this summer. If you are considering upgrading 14 to 16 inch on a 23FB, I'm almost certain it won't work due to inadequate room in the wheel well front and back. Even if there were room, it would be unwise to do a two inch wheel/tire upgrade without upgrading the OEM 10 inch brakes.
You'll be happy with the 15 inch wheels/tires, you will have plenty of weight capacity and safe and capable tires.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-19-2015, 10:42 AM   #47
Thanks everyone. looks like the 15" is probably the best option if we move forward with the 23FB. We installed a Dexter lift kit on our Bambi, and it raised the trailer about 2", as measured at the wheel well; has anyone installed a lift kit on a 23?
Old 01-19-2015, 12:20 PM   #48
interstateflyer's Avatar
2017 25' International
Los Osos , California
I put Michelin P235/75R15 LTX M/S2 load range XL and Sendel T03 wheels on our 2014 23D just after purchasing the trailer. Got everything at America's Tire (Discount Tire). These are the wheels Airstream pairs with Michelins on the Eddie Bauer.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 01-19-2015, 01:31 PM   #49
on looking at a photo, it looks like there would be sufficient clearance to go to 16", especially if a lift kit was installed.
<LI class=photoThumb>
Old 01-19-2015, 01:52 PM   #50
TinTin's Avatar
Canmore , Alberta
Steamy1:
Can't help you with regard to lift kits, whether they're a good idea or not. Regarding fit, the attached picture shows 15 inch wheels (without centre caps yet) on my unit, very tight especially toward the front (left).
When I was doing my wheel/tire research, I did read a number of reports regarding wheel upsizing and brakes. If you were to decide to try the 16 inch wheels, it would be advisable to go with new hubs and 12 inch brakes. The 2" increase in wheel size may cause overheating of the original 10 inch brakes. Nearly every source I read suggested that one inch increase should not require any change in brakes.
YRMV.
Bob and Nancy
Old 01-19-2015, 01:58 PM   #51
any idea what the Load Index "108" translates into total pounds of carrying capacity? I dug around the Michelin website but could not seem to find a conversion table. With using an alpha "load range", it gives actual pounds of load carrying capacity.
Also, which SenDel Item Number wheel did you go with?
Many thanks,
Old 01-19-2015, 02:02 PM   #52
Originally Posted by TinTin View Post
Steamy1:
YRMV.
Attachment 230729
Thanks for the valuable info. looks like I should abandon the 16" obsession and go with the 15". Appreciate the insight and photo.
Old 01-19-2015, 02:10 PM   #53
TinTin's Avatar
Canmore , Alberta
Many thanks,
Load rating on the 15 inch Michelin LTX is 2150 lbs at 50 psi. For trailer use you have to downgrade the weight rating by 10% which takes you to 1935 lbs.
Bob and Nancy
Old 01-19-2015, 02:27 PM   #54
2008 23' Safari SE
2007 Base Camp
Hi Steamy1 - TinTin makes a good point about the load capacity of the 15" tires relative to the weight of the 23' trailer. The gross weight of your trailer is only 6,000 pounds, or 1,500 pounds per wheel fully loaded. Plus, several hundred pounds of this are transferred to the TV as hitch weight. Therefore, the 15" wheel/tire combo gives you way more than enough safety margin.
Old 01-19-2015, 02:47 PM   #55
Many Thanks for the valuable information. It seems like a high percentage of discussion topics somehow morph into a tire/wheel/TowVehicle/bike rack/hitch discussion.......
Old 01-19-2015, 03:10 PM   #56
2008 23' Safari SE
2007 Base Camp
Steamy1 -- to correct possible confusion on my last post about load per wheel: the load per wheel on your current 19' (4,500 pound) trailer is 2,250 per wheel. On the 23' (6,000 pound) it is only 1,500 pounds per wheel.
That is why the 15" wheel/tire setup is more than enough for the 23', and of concern to some on single axle Airstreams and the larger models.
Newbie help request from Newbie southsaglejim Plumbing - Systems & Fixtures 18 09-10-2014 08:39 PM
Newbie needs help in purchasing an 'online' trailer Lady Bird Dollars & Cents 7 09-20-2011 09:18 PM
Newbie - first Trailer, a 30 ft International alozier Member Introductions 15 07-26-2011 01:56 PM
Newbie ?? about 25' vs. 28' Trailer Pinky65 Buyer Guidelines 13 01-26-2011 11:22 PM
Newbie in WI looking for big trailer. Howdy! offgrid Member Introductions 4 05-28-2008 09:51 PM
