Old 05-12-2005, 08:09 PM   #1
John and Anne's Avatar
warrenville , Illinois
12V or 24V outlet for tv
My '96 land yacht has a cabinet with an ac/dc tv in the rear bedroom. The cabinet has a 110v and a 12v cigarette lighter plug in it. The old tv was plugged into the 110. I checked the cigarette lighter plug and found it carries 24v at the leads connected to it. Anyone have an idea if this is how it is supposed to be or is it not wired correctly. I bought the rv a few years ago, and am not sure if it was wired this way at the factory or if this is an add-on. Any help would be appreciated.
thanks!
John
John and Anne is offline   Reply With Quote
Old 05-12-2005, 09:18 PM   #2
LOST , Hawaii
Have you checked voltage anywhere else? Do you have 2 12v house batteries? Someone possibly installed them in series instead of parallel. 24 volt is usually military or big trucks, have you check the voltage requirement for the refrigerator, furnace and water heater?
John
74Argosy24MH is offline   Reply With Quote
Old 05-12-2005, 09:50 PM   #3
Images: 59
There are appliances available in 24Vdc, but they are mostly for marine or aviation applications. Especially for high load uses like windlasses and bow thrusters.
It's possible the PO put in a special 24V outlet, but he should have used a different receptacle to eliminate confusion.
Old 05-16-2005, 12:09 PM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I have four of those outlets with 110 and a cigarette lighter outlet and all of them register 12V. Further my wiring diagram shows no 24V oulets in tha coach. I would say you have a problem somewhere or something was changed along the way.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
12v
24v heading to the lights instead of 12v kylewbenson Electrical - Systems, Generators, Batteries & Solar 8 06-23-2012 04:42 AM
24V panel and 12V battery? timzog Generators & Solar Power 10 03-14-2012 01:44 PM
Need a 24V fresh water pump Darkspeed Fresh Water Systems 16 07-28-2011 07:23 PM
Need to convert 24V DC to 12V DC for fridge igniter bacevedo Refrigerators 6 03-12-2011 07:34 PM
Thermostat - 24V or 12V Larry71 Electrical - Systems, Generators, Batteries & Solar 2 08-27-2004 06:02 PM
