Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 03-12-2007, 10:33 PM   #1
philippes
philippes's Avatar
Profile:  Cincinnati , Ohio
1/4" Compression fitting for air suspension line
I have a Classic 36' 1994 Motorhome.
Do you know where I can find the air compression fittings that are fitted on the plastic airlines. There are 1/4". Not anymore liverable at Airstream. Airstream told me to go to NAPA. Napa has a model that do not have the right shoulder and cone angle.
Thank you in advance for your help.
Philip
philippes is offline   Reply With Quote
Old 03-13-2007, 01:51 AM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Unless you have an oddball fitting, go to any Ace or other reputable hardware store. I have always found them there.
Dave
Fyrzowt is offline   Reply With Quote
Old 03-13-2007, 07:36 AM   #3
overlander63
overlander63's Avatar
Profile:  .... , California
Brass double ended compression fittings are about a dollar from Ace. If it is a manufacturer-specific compression fitting to go directly on a shock, that is when you need to go to Napa and get a line kit.
(that guy from Inland RV)
Old 03-17-2007, 09:17 PM   #4
philippes
philippes's Avatar
Thanks. The Ace hardware are normal double cones. They do not match my fittings. Napa has one, which unfortunately had a different cone angle than the genuine Airstream one. Help is still appreciated.
Philip
Old 03-17-2007, 09:51 PM   #5
markdoane
Profile:  , Minnesota
Images: 59
Have you tried Parker Hannifin?
LP supply line uwe LP Gas, Piping, Tanks & Regulators 8 09-17-2006 05:12 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 04:08 PM
2002 Classic 25' suspension? Kistler Airstream Trailer Forums 7 11-12-2002 02:01 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
