Old 01-22-2012, 07:04 AM   #1
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
'04 Land Yacht Generator Question
When I have the generator running on my '04 Land Yacht 30, and I turn Off the House Battery Switch at the door of the MH, the generator shuts down. Is that normal? Does it need battery power to continue running?
Thanks folks!
RAG is offline   Reply With Quote
Old 01-22-2012, 08:09 AM   #2
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Our Genset is much older, but that does not sound right. It should have its own source of electricity to spark the coil and plugs. I'm pretty sure ours runs off the vehicle battery which you can't turn off.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 01-22-2012, 08:18 AM   #3
RAG
RAG's Avatar
Thanks for the response.......
This Genset definitely starts off the House batteries. The '04 has separate Chassis and House battery On/Off Switches, so I'm sure of it.
Old 01-22-2012, 08:46 AM   #4
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
The genset should produce spark from it's own power source once started.
92landyacht is offline   Reply With Quote
Old 01-22-2012, 08:50 AM   #5
2000 31' Land Yacht
Fort Erie , Ontario
RAG
Can you start the genny with the house battery switch in off position? I can't recall how mine works will check it out later to-day. BTW my genny is the Onan 5.5BGM, what is yours? Also, have you ever changed the rear spark plug on yours?
Steve
is.chowa is offline   Reply With Quote
Old 01-22-2012, 11:10 AM   #6
RAG
RAG's Avatar
Originally Posted by is.chowa View Post
RAG
No, the House Battery switch must be On.
The Chassis Battery switch is irrelevant; On or Off, makes no difference.
The generator is an Onan Marquis Gold 5500; 186 hours.
Never changed plugs, as it starts and runs fine. I've only owned the rig for 2 months.
Is it possible for an electronic magneto to go bad on a 186 hour unit?
Old 01-22-2012, 02:13 PM   #7
1992 36' Land Yacht
Grayson , Georgia
It's not the hours... It's the lack of use that hurts generators. My Onan Marquis 7000 (not Gold) will run with no battery connected once it's started. I'm looking for the service manual for your genset. If I get a copy I'll pass it on. If you can post the model number and serial number that will help locate it.
Old 01-22-2012, 05:24 PM   #8
1992 36' Land Yacht
Grayson , Georgia
If your interested I did find a copy of the factory service manual for your genset in PDF format. It should give you all the diagnostics information you're looking for. You can download it at this link 983-0501D.pdf or I can email it to you if you want.
Old 01-27-2012, 04:04 PM   #9
2000 31' Land Yacht
Fort Erie , Ontario
On my ASLY2000 the Marquis 5.5 BGM runs with or without the switch at door in either off or on positions. Not sure about your coach. Here is a link to www.flightsystems.com for the rv generator troubleshooting guide. Your coach electrical schematic might help.
Regards,
Steve
