Old 09-04-2013, 05:11 PM   #1
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
What was the finish on a '61 Bambi?
I've been doing a "full monte" to the "li'l bambi", a 1961 Ohio built Bambi. I've had to replace furniture/interior and need to refinish the new and old stripped wood. Any suggestions on how a typical AS of the period was finished. Stain and sealant? www.lilbambi.net
surfpod is offline   Reply With Quote
Old 09-04-2013, 07:01 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I though they had stained the wood. Some have a lighter oak shade and others are a mahogandy. The walls were Zolotone paint. Zolotone is has specs of other colors in it and can not be touched up. It is applied with a special paint gun with a spining head.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 09-04-2013, 10:47 PM   #3
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
They used a toned (dyed) lacquer. I pretty sure they sprayed a clear lacquer on the wood, then sprayed lacquer with dye in it to achieve the desired color. Then they may have sprayed another final coat of clear on it.
Thalweg is offline   Reply With Quote
Old 09-05-2013, 02:11 PM   #4
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
Surfpod,
I've been looking at your webpage. It looks like you're doing an impressive job with the restoration, and documenting it very well.
If you intend to go back to the previous color on your cabinetry, it'd be an easy color to match with Transtint dyes, which are available at Woodcraft or Rocklers. It looks like a mahogany color to me. I'd mix some of that into some lacquer and spray it on. It'd match the original perfectly. If you've never shot lacquer, it's pretty simple. It dries much faster than poly, so less dust problems. Use gloss sheen, and if it's too shiny, spray satin for the last coat.
Keep up the good work!
Old 09-05-2013, 03:46 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Zolatone
Originally Posted by Bigventure View Post
The walls were Zolotone paint. Zolotone is has specs of other colors in it...
True.
Not exactly...while the original OEM 1961 color has been discontinued, if you have small areas (like rivets or scratches) that need to be touched up - it can be done with model paint, a very small brush & patience. We did this on our 1964 GlobeTrotter when we had it. If you want to re-do the whole thing, Zolatone is still made.
We re-sprayed our entire interior when Zolatone during our restoration. It does not require a "special paint gun with a spinning head", we used an airless sprayer with GREAT results see the process / end results in our "It's a Girl!!!" thread starting at post #269
Good luck in whatever you decide to do ~
Shari
Old 09-06-2013, 06:37 AM   #6
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Thanks for all your help! The furniture in this AS had been stained/sealed sometime years later to a darker color. Definitely want to respray the interior and will research and listen to some of thevap.com podcasts dealing with that subject. Again, thanks for your help.
Mysterious Electronics - 2007 19' Bambi randf Electrical - Systems, Generators, Batteries & Solar 15 05-31-2012 05:11 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
