Old 07-30-2011, 12:05 AM   #43
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Saaayy, Look what followed us home today!
Greetings Dave and Brenda!
Originally Posted by Skellington View Post
Thanks very much for your input and information!! Very much appreciated! Please explain for me what exactly is needed for trailer vs. Automotive tires? What will I be looking for? I take it they will be labeled ST or Trailer on them? Is the size right? Meaning the 165/70? Or should I be looking for something else?
Thank you again!! Dave and Brenda
The following are a few of the differences between trailer tires and automotive tires:
  • Sidewalls are heavier than passenger tires.
  • Tread ply rating typically is either 6-ply or 8-ply rated rather than the 4-ply that is typical for a passenger tire.
  • The rubber compounding is different on trailer tires to compensate for the long periods of inactivity typically experienced by trailer tires.
  • Trailer tires are typically rated to carry significantly more weight than a similar sized automobile tire.
Due to variations in coach construction (wheel well size and axle placement relative to wheel well) it is difficult to give a precise size designation when the tires currently on the coach are not of the correct. It is usually best to select a tire with a carrying capacity that gives you at least a 20% margin of safety above the maximum gross vehicle weight rating of your coach. With a Vintage coach measuring is almost a requirement when purchasing new tires to be certain that they will fit within the wheel wells and have a rating to carry the coach's maximum weight.
I have friends who have switched their Vintage Bambis over to either 14" or 15" wheels to take advntage of tires that are easier to find or have a higher carrying capacity.
Good luck with your investigation!
Kevin
P.S.: The sidewalls will be labeled ST and the load range should be labeled as B, C, D, or E. It is unusual to find greater than a C load rating for 13-inch ST tires.
Kevin D. Allen
AIR #827
Old 07-30-2011, 09:28 AM   #44
ALUMINUT
Bonnie Disch's Avatar
2006 22' International CCD
Radcliff , Kentucky
I love it, and the little door window as well..:-)
Bonnie
DISCH
Bonnie Disch is offline   Reply With Quote
Old 08-02-2011, 08:52 PM   #45
1956 22' Flying Cloud
1961 16' Bambi
Calgary , Alberta
Anybody know the tire size needed for our 61 Bambi? Or what will fit original rims? Or how wide a tire fits on the original rims? I know they are 13 inch, but what was the original width and height/series tire?
I have found a local company that has ST 175/80 13's and I was wondering if they will fit properly.
Thanks, Dave and Brenda
Skellington is offline   Reply With Quote
Old 08-02-2011, 09:04 PM   #46
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
There isn't a definitive answer for your question as there was a tremendous variance of room in the wheel wells on Vintage Bambis. Typically, the safest method is to measure the availalbe room prior to purchasing your tires and/or rims. Vintage Bambis were basically hand-made so variances are common both in available height and width of the wheel well. If you don't feel comfortable making these measurements, make it a condition of the purchase that the tire dealer will perform the necessary measurements to verify that the new tires will fit . . . I did this with the first two sets of tires purchased for my Overlander.
Kevin
Kevin D. Allen
AIR #827
A Silver Lining is going to a new home today swanky Classic Motorhomes 15 08-28-2009 10:52 AM
Brand New '64 Globetrotter came home today GlobeTrottin Member Introductions 10 08-29-2007 09:59 AM
brought my 63 globetrotter home today 1963gt Member Introductions 16 05-30-2007 12:12 PM
19 Foot Bambi Home Today. firedog Member Introductions 24 07-12-2006 03:57 PM
I Washed My Motor Home Outside Today! Chaplain Kent Classic Motorhomes 11 01-15-2006 11:25 AM
