Old 06-26-2010, 08:34 AM   #29
1956 26' Cruiser/Overlander
1961 16' Bambi
longmont , Colorado
Hey, I have the first Ca Bambi. Needs both front couches. Does anyone know of any available? I have seen drawings of how to make them but thought it might be easier to find existing ones. Replaced the door handle with a rare new one-Bargman 77-broken handle thing. My door is a suicide one and had to use old parts to convert the new handle to open from the right to left side.
busboy is offline   Reply With Quote
Old 06-27-2010, 11:58 AM   #30
1961 16' Bambi
1967 17' Caravel
Tempe , Arizona
Images: 27
According to the info below, the Ohio Bambi's started at 101 so abased on this you would have #4:
I don't have a complete serial number range (beginning or ending serial numbers) for 1962 Ohio built Bambis. Nevertheless, it appears Ohio built 1962 Bambi serial numbers began at or near 162T401 and went up from there, to at least 162T467. Your 162T419 falls comfortably within that range.
The 250 1961 Ohio built Bambis appear to have serial numbers starting at 161T101 and ending near 161T350. Known low and high 1961 Ohio built Bambi serial numbers are 161T124 and 161T346, thus suggesting the above estimated range of 250 sequential numbers.
The 350 ending sequential number for 1961 Ohio built Bambis leaves open the possibiliy that 1962 Ohio built Bambi serial numbers may have begun 351, but to date no numbers under 401 have been discovered for 1962 Bambis.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Puggzilla is offline   Reply With Quote
Old 06-28-2010, 11:51 AM   #31
1961 16' Bambi
longmont , Colorado
I have the oldest, 01 California 1961 Bambi.
Old 06-29-2010, 04:40 PM   #32
1961 16' Bambi
Salt Lake City , Utah
So I gather I've got the oldest Ohio Bambi, so far. unless # 1,2,& 3 turn up.
Thanks for the information everyone.
When I pulled this baby home, the packrat nests had grown to 3' deep inside with all of the expected fluid & deposits included. But the trailer was 100% intact & original. The aluminum was all in good shape, and covered by a coat of camouflage paint that has been awful to remove. The rodent tenants had moved in under the floor and inside the walls, necessating all floor and wall insulation replacement. All kinds of strange things were growing in the appliances, water & gas lines, and the inside paint, cabinets & upholstry were saturated with their wonderfully fragrant nectar.
So needless to say, I'm in the middle of a complete ground up restoration. Belly skin, floor, insulation, interior skin removal, stripping & reinstallation, wiring replacement, all are done. Now ready for the Zolatone interior paint, and just finished reglazing & polishing the window frames today. I'll post some photos (when I get time?)
One question if anyone knows, this trailer has the original axel with a 4 lug wheel. The 14" wheels & tires on it now seem large, & have very little clearance. Were the original wheels 13"?
Also all of the appliances work and are being resrored to original condition. One of the few things I am missing are the interior plastic removable door shelves from the Dometic M16 refrigerator. I suspect a difficult thing to come by. Any lines on possible source would be greatly appriciated.
I hope to have a full photo essay of the restoration. and thank those who have preceeded me for their documenting of the processes. Your information has been extremely helpful.
Neonguy
Neonguy is offline   Reply With Quote
Old 07-14-2010, 11:44 PM   #33
billnovus1
1961 16' Bambi
Salinas , California
61 Bambi
Hi, just acquired 16TDSS1639, 39th built in Santa Fe, Ca. Found her on the Central Coast of Ca., she had been sitting for the past 25 years. Surprisingly good shape, all orginal except for some carpet. Pulled her home (10 miles) with no problems, think she would like to hit the road soon. Cleaned up real nice, old Ca. license plate and all. Got lucky.
novus1 is offline   Reply With Quote
Old 07-15-2010, 07:35 AM   #34
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Congratulations!! She sounds like a beauty. Post some pictures and welcome to the forums.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-10-2010, 05:13 PM   #35
1961 16' Bambi
Thought you all might like to see some photos of Ohio #4 as found literally FULL of varment nests.
ID:	110461   Click image for larger version
ID:	110463   Click image for larger version
Old 10-14-2010, 09:14 PM   #36
1961 16' Bambi
none , Georgia
hello everyone just got my bambi 1962 and was reading this forum and according to my serial number on the side on the trailer I have number 162T472 this is a higher number than what is posted earlier can you help.Puggzilla or anyone.
61bambi472 is offline   Reply With Quote
Old 10-14-2010, 09:18 PM   #37
1961 16' Bambi
none , Georgia
just noticed i messed up on my user name should of been 62
Old 08-25-2013, 09:34 PM   #38
1961 16' Bambi
longmont , Colorado
oldest Bambi
I proudly possess a California Bambi with serial number 16tdss1601
Old 08-25-2013, 09:49 PM   #39
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey busboy
I think mine is the youngest its a California #1942
Tim
Beaker63 is offline   Reply With Quote
Old 08-26-2013, 09:48 AM   #40
Silver Lamb
EweMama's Avatar
1969 27' Overlander
1961 16' Bambi
Bonner Springs , Kansas
Busboy has the oldest California-made 1961 Bambi with 1601. Congratulations!
How is Novus1 & Neonguy doing with their "fixin' up" their Bambi finds?
EweMama is offline   Reply With Quote
Old 08-26-2013, 10:18 AM   #41
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Lightbulb
If you want, you can change it to 62 my contacting a Moderator or Admin via PM...
Shari
Old 08-26-2013, 01:18 PM   #42
1961 16' Bambi
longmont , Colorado
oldest Bambi
Well I just found out that my 61 Bambi needs a new axle and that the earlier ones had the axle welded to the frame...SO I have to cut it off and fabricate a new mounting plate for a new axle. Also interested to find out if my inner upper shell ends are made of aluminum or fiberglass. Rear bumper is basic angle iron type that is part of frame extension.
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
