Old 11-30-2005, 05:13 PM   #1
RichardT's Avatar
New to me 1963 Bambi
I just got back tonight from picking up a 1963 Bambi it is
serial # 161T200
and I am a little confused as the toilet is on the Street side.
Where was it made, CA or Ohio?
Also the door is non suicide with jalousie window if that is significant .
I looked up the Bambi serial number guide and I dont see what I want to know, what were the production run serial numbers for 63?
I am an extremely lucky guy, the floor is solid with no signs of rot (passed the ice pick test!) Everything is there. The skin is as good as I have seen. (And I have seen alot!)
It has not been registered or used in over 25 years and while it is dirty it has the original Zolatone which is solid and appears that it will clean up nicely.
It is in very original unmolested condition.
It is a keeper.
RichardT
Pictures tommorrow!
RichardT is offline   Reply With Quote
Old 11-30-2005, 06:34 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Richard
Congradulations - non of the doors on Bambis are the suicide type...
can't wait to see the pictures....
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-30-2005, 06:53 PM   #3
RichardT's Avatar
"For 1961 and 1962, the easiest way to tell a California from Ohio Bambi is the location of the toilet - streetside from California, curbside from Ohio. "
That is a quote that I am curious about, in 63 were both Ohio and CA streetside?
Also I have seen alot of Bambi pictures showing trailers with suicide doors and did not know if one way or the other was more common.
Old 11-30-2005, 07:34 PM   #4
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Super Bambi
Sounds like you have a great Bambi. We bought our Bambi in August in Utah. It's mostly apart right now. Ours is a California model. It was in good condition acept for the floor and water lines. I had been full of water during a bad freeze sometime in its past. Would very much like to see pictures of yours.
Don
NorCal Bambi is offline   Reply With Quote
Old 11-30-2005, 07:43 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Richard, congratualtions on the new Bambi. I think, though, that you have a 1961, not a 63, from the serial number. I have been wrong before, but the third digit in the early 60's should denote the model year.
You show youe serial as: 161T200
Old 11-30-2005, 07:53 PM   #6
RichardT's Avatar
Here is the answer!
Re: Hi from Bat Cave
Originally Posted by RichardT
  • Hi I got a nice little 63 Bambi today and was hoping you could tell me more about it
  • Serial # 163T200 - toilet streetside
  • CA or OH?
  • What sequential #'s used in 63?
  • Thank you so much.
  • RichardT
Hi Richard:
Its an Ohio built Bambi from the serial number, but with the change in 1961 to the large rectangular serial number plates, the "built-at" is the only factory listed on the serial number tag. So, the s/n plate for this trailer should read "Jackson Center, Ohio" across the bottom. This rule should hold true for 1961 and later years, as each factory had its own serial number plate from 1961 on.
In 1963, all toilets were standardized at both factories to the street side, so that earlier difference disappears beginning in 1963.
I don't have beginning or ending serial numbers for 1963 Ohio trailers, but I have seen Bambi numbers both below and above T200, so yours is somewhere in a very wide middle. Hope this helps.
Best regards,
Fred C.
Fred Coldwell, #1510
VAC Historian
Rocky Mt. VAC Rally Webapprentice
2005 VAC Rocky Mt. Rally
Old 11-30-2005, 10:11 PM   #7
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That Fred is an amazing guy. Glad he's on our side.
I'll just bet he has libraries upon libraries of information and reference material. But then that's what a historian does.
Thanks Fred for all your work and dedication.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-01-2005, 11:12 AM   #8
RichardT's Avatar
63 Bambi
Here is the first picture of it.
Old 12-01-2005, 11:06 PM   #9
1963 16' Bambi
Yreka , California
Images: 21
RichardT
Thanks for the picture. It looks pretty familiar. Keep the pictures coming.
Don
Old 12-03-2005, 08:24 PM   #10
RichardT's Avatar
I am the second owner, how cool is that?
Old 12-03-2005, 09:35 PM   #11
moogie32's Avatar
1967 22' Safari
Branford , Connecticut
Images: 11
Wow!
Oh, Richard!
It's beautiful! Now we just to need to see the interior.......Way to go!
Diane
moogie32 is offline   Reply With Quote
Old 02-05-2006, 10:45 AM   #12
Melody Ranch's Avatar
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
suicide doors on 63 Bambi
More than one lister says no Bambi has suicide doors. Sorry....I have one. Vintage Airstream shows pictures of others. I don't like it...but thats the way it is.
How about the variety of back panels...many louver patterns and access doors....can't figure that one out.
Old 02-05-2006, 11:21 AM   #13
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Richard,
Congratulations on your new Bambi. You certainly have a knack for finding the unusual.
Do you provide tours of the Bat cave?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 02-05-2006, 11:34 AM   #14
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Melody Ranch ~
The reason for all of the louvers and access doors under the rear window is becuase that's typically where the fridge and stovetop are located. They both need to have access and the fridge needs to vent to the outside. Can't run a vent up and out the roof because of the placement of the window.
FF
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
