Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 1961 - 1963 Bambi
Old 06-07-2009, 12:52 PM   #1
Profile:  1961 16' Bambi
South Portland , Maine
Need 1961 Ohio bambi dimensions!
I have one, but it isn't here, so I can't measure it! Can anyone help? I need to know the length (total), height and width so I can figure out if it will fit into our garage before I clean all the junk out of it.
Thanks!
mudseason is offline   Reply With Quote
Old 06-07-2009, 01:42 PM   #2
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
I had a '61 Ohio Bambi for several years, but don't have it now... but even if someone does come up with those dimensions for you, recognize that yours may not actually be the same, particularly in height. First, there's the A/C-no A/C option issue. An A/C unit will raise the height nearly a foot. Second is the degree of axle rubber decay. An old, worn out axle will let the coach ride as much as 3" lower than a new axle, which would also affect height.
Frankly, IIRC, the interior height of the Bambi was about 6'4", so that puts the exterior over-all height (without AC), with tires on well over 7 feet tall... if yours is a standard-clearance garage door, it's doubtful it will fit.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
1994 Airstream B190 & 2006 Bigfoot 25B25RQ
Old 06-07-2009, 02:20 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
If height is a problem, and it has to go in the garage, you may be able to sneak the trailer in by removing the air from the tires, or even removing the tires completely. If it is worth the trouble. You'll probably gain about 6 inches by doing this. The trailer is less than 17 feet long, and less than 7 feet, 8 inches wide.
Old 06-07-2009, 07:26 PM   #4
Profile:  1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
Smile Bambi size
We went to measure our 62 Ohio Bambi.....7'w..8'h..16'6''L...good luck
62bam is offline   Reply With Quote
Old 06-07-2009, 07:29 PM   #5
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
the above is with NO a.c.
Old 06-11-2009, 09:22 AM   #6
Thanks everyone - I measured the garage and the airstream absolutely will not fit, which is a bummer, but at least I don't have to clean it!
1961 Bambi in S.C. rbrown Member Introductions 5 05-22-2007 09:44 AM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 20 05-14-2007 01:28 PM
Introductions and selling my BAMBI 1961 Tailspire Member Introductions 1 01-20-2007 12:43 PM
1961 Bambi $6500 fabofabo For Sale & Wanted 6 07-31-2004 08:20 PM
1961 Bambi for $1000! yukionna On The Road... 4 06-20-2004 06:26 PM
