Originally Posted by Mrs. C We're going from the Bambi's 6 wire setup to a standard 4 way connector. Any advice would be greatly appreciated. Thanks!  |
You do need to stay with the six wire plug system. The four wire plug does not have brakes.
Here is a link to a plug, that is the kind that needs to be on there. If you look at the pictures down below, you will see a diagram in the pictures of how it needs to be wired. You can print that and take it to the vehicle.
Here is the link.
Dan
