Old 03-12-2006, 08:30 AM   #1
RichardT's Avatar
How level is level?
Re: MC16 Dometic gas only refrig.
It appears as with all of the appliances to be relitively unused and complete. It lights easily and I cleaned everything and adjusted the burner flame by the book.
I cannot get it to cool at all. I was able to check the level of it just before bed last night and found I am very close side to side and close but a little less close front to rear of the box (I am within the lines).
I will try to get it more level this evening.
How level is level? What else can it be?
RichardT
RichardT is offline   Reply With Quote
Old 03-12-2006, 08:55 AM   #2
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
If it is like mine, it is an amonia refrigerator and if it has a pin jole leak the amonia is gone and it won't cool. See if there is any corosian on the coils in the back. These coils can repaired or replaced, but I did that and it only lasted a couple years. I ended up replacing the frig.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-12-2006, 09:08 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Though level is more important with the older fridges, ditto what cooperhawk posted. Never saw this issue until my parents SOB Dometic sprung a leak. After the smell was gone, the unit seemed to operate as expected, yet no cool. I'm guessing that the ammonia in the system is purged and although there is a pretty blue flame, there is nothing to react with it.
Dad took his to a place that fixed it up in the U.P of MI. So far it's been 3 seasons of use since the repair and before that the orig unit lasted 22 years.
Old 03-12-2006, 09:22 AM   #4
The Hawk's Lair
cooperhawk's Avatar
There are several repair places on the web. I took mine to an old man in Minneapolis who was a retired farmer. He sat in his garage in his under shirt and soldered these things all day. He fixed it by cutting our and replacing a piece of the coil. A couple years later it sprang a leak in another place.
Here are a few:
http://www.rvfridge.com
http://www.nucold.com
http://www.rvcool.com
AKA THE GUNNER
VFW, LEGION, NRA
Old 03-12-2006, 10:13 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Leaking units will operate normally in every sense except one.......they WON'T COOL. That is because there is no ammonia or hydrogen left in the cooling units.
In my experience, RV type refrigerators can NOT be repaired with any lasting success. The coolant in these is a VERY PRECISE mix of ammonia, hydrogen gas, water and an anti-corrosive called sodium chromate. It is the sodium chromate that you see when it leaks (yellow) and the ammonia that you smell. The only company I have found that can do that for you and that can replace the required refrigerant if Ford & Ford in KY. Still, prices are what should be the deciding factor. as well as warranty coverage.
If you have a leaking unit, you have 2 options: replace the cooling unit (entire back of the frig) or replace the entire frig. I've replaced at least a dozen cooling units in the last few months. It's not a really big deal! Just follow the instructions carefully.
The aftermarket companies sell cooling units for just about any Norcold or Dometic out there. The OEM units are VERY expensive.......50-75% of the cost of a new unit. It's a tough decision which way to go
Old 03-12-2006, 02:31 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by RichardT
... How level is level? ...
Richard,
Really close appears to be best. I asked this question at one point, and never figured out what was good enough.
I try to stay within a quarter bubble.
Tom
Old 03-12-2006, 03:12 PM   #7
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
If you can comfrotablely sleep on the bed then it is close enough. It doesn't have to be far off level to make sleeping uncomfortable.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-12-2006, 03:52 PM   #8
TomW's Avatar
1967 26' Overlander
Originally Posted by Tarheel
If you can comfrotablely sleep on the bed then it is close enough...
That assumes the refrigerator is plumb with the floor.
If it is a vintage trailer, one would be wise to check the freezer's bubble level with respect to how level the rest of the trailer feels.
Tom
Tank level indicator panel mcostanzo 2003 Safari 7 11-07-2003 09:27 AM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
