Old 07-30-2013, 04:51 PM   #1
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
bellypan aluminum
I'm working on a 1961 Bambi and need to replace the belly pan. Does anyone know the type of aluminum and thickness of the 61 Bambi belly pan?
surfpod is offline   Reply With Quote
Old 07-30-2013, 05:20 PM   #2
65CV's Avatar
Western , Massachusetts
.032 5052 Al Sheet
https://www.airpartsinc.com/shopexd.asp?id=298
65CV is offline   Reply With Quote
Old 07-30-2013, 05:35 PM   #3
DFlores's Avatar
1968 22' Safari
That is expensive
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-30-2013, 05:39 PM   #4
DFlores's Avatar
1968 22' Safari
Get a price from these guys
http://metals4u.com/
DFlores
David & Diana
Old 07-30-2013, 05:46 PM   #5
65CV's Avatar
That's the second time in two days that I've gone out of my way to share a link that I've used. Also the second time I've been chided for it.
Maybe my sources aren't the best prices.
Should I stop quoting sources?
Old 07-30-2013, 06:13 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Face it there are a lot of shoppers here.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-30-2013, 06:51 PM   #7
mapleton , Utah
For 5052 sheets check with your local HVAC shops/suppliers. May cost a little more but no shipping costs!
Depending on who you ask you can use anything from .025 to .040.
I used .032 in 4x10 sheets and am pretty happy with how mine turned out.
tim
rumrunner is offline   Reply With Quote
Old 07-30-2013, 07:36 PM   #8
65CV's Avatar
No.
It was a rhetorical question.
Old 07-30-2013, 08:01 PM   #9
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I bought .032" 3003 from Aircraft Spruce:
https://www.aircraftspruce.com/catal...03_alsheet.php
apparently the 5052 and 3003 are made for the same purposes, w/ 5052 being more "advanced" . . . I think I went w/ the 3003 because I could buy it in longer sheets. Basically you want "workability" . . . both of these alloys are "soft" and tend to hold the shape you give them, vs. something like 2024 which is very springy, resistant to change . . .
I'm pretty happy with the stuff (other than the mental break down I had while trying to install new belly pan at the corners w/shell and frame still "attached" . . . it would have been so much easier as a "shell off" . . . and even better if you can flip the frame over).
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 07-30-2013, 09:57 PM   #10
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I used .032" 6061-T6 Aluminum. Thicker than the original, easy to work with. I did several online searches until I found it locally. It was only available in 48" wide coils, but they cut to length, so I ordered 4 pieces 62"x48" and overlapped them. So far I think the installation is superior to the original. I'll know in 41 years
DryFly is offline   Reply With Quote
Old 07-31-2013, 05:16 PM   #11
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Thanks all for your help! This is for a 1961 built in Ohio and she needs a little help! Some pictures can be seen at www.lilbambi.net
