Old 04-24-2018, 06:35 PM   #1
1977 31' Sovereign
1996 30' Land Yacht
Riverview , Florida
62 bambi floor dimensions
I finally removed the shell from the frame and got the floor and belly skin off. Unfortunately the floor is so rotten in the rear I can't tell what the radius and dimension the floor should be. The C channel was barely attached to the floor and was mostly attached to nothing in the corners as the wood was gone. I can get a good idea from the shell but if someone has any measurements it would be appreciated. BTW it was a good thing I tore all down to the frame. One cross member was completely missing along with one longitudinal piece and two other cross members have severe rust holes. Off to the welder then blasting and power coat. TIA for any info
pryner is offline   Reply With Quote
Dimensions of the floor plan 1969 Ambassador robbarley 1966 - 1969 Ambassador 1 01-04-2011 03:40 PM
Need 1961 Ohio Bambi dimensions! mudseason 1961 - 1963 Bambi 6 10-26-2010 11:37 AM
Floor dimensions needed uwe Repairing/Replacing Floor &/or Frame 4 08-15-2004 06:26 AM
Cushion Dimensions, Front Sofa Alan and Julie General Interior Topics 2 08-05-2002 02:14 PM
