11-11-2011, 01:14 PM
1961 16' Bambi
Malden
, Missouri
'61 Bambi plumbing
I was just BLESSED with a '61 Bambi, and I'm excited about being a Airstreamer! I did a once-over of the belly, and found that there's a black sewer line that begins at the sink on the street-side (it's an OH made one) follows to the front and across the front, then routes all the way down to the back of the curb-side.
Can anyone tell me WHY it take's that path? Does that sound original or was the original plumbing concealed in the belly?
I know I'll have more questions once I get to examine her more closely, but I thought I'd start with this one that's bugging me.
Thanks in advance for your input!
11-11-2011, 01:20 PM
2002 25' Safari
Dewey
Welcome to the forums.
Congratulations on the 61 Bambi, I would love to own one myself.
The sewer line may have been installed to give the trailer a little storage for grey water since there was no grey water tank.
Richard
11-11-2011, 01:23 PM
2006 19' Safari SE
Tucson
You might contact member "61 Bambi"...they might be able to help you out with answers. Sweet Rig.
Oh! Welcome to the Forums! You're in the right place!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
09-22-2013, 11:49 PM
1964 26' Overlander
longmont
Has anyone installed a grey water tank? AM looking for dimensions for such a tank.
09-23-2013, 06:19 AM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
That would most likely be added to give you some room to store a little grey water before overflowing into the shower. There was no grey water storage at all on the Bambi originally.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
09-23-2013, 08:40 AM
1964 26' Overlander
Richmond
, Virginia
I'm about to on a '64 Overlander. The hardest part is figuring out how to tie the systems together so you dont have 2 seperate hookups. I don't know how the Bambi is laid out. The other hard part of these trailers is that the frame is so shallow, even though it would be easy to put a bottom mounted dump valve, it would get torn off if you had anything in the road.
On mine, I have a belly pan that wraps to the center. I am jacking my trailer several feet off the ground, dropping the axles, and then letting the belly pan fall so I have the center open. Then, I'm putting in the gray tanks, right above the axles.
You can order shallow gray tanks from Vintage Trailer supply. However, you will need to carefully measure where the fittings will go as they need to go through the open channels in your frame members. There's only so much wiggle room.
09-24-2013, 12:07 PM
1971 27' Overlander
Austin
61 Bambi Plumbing
Welcome to Bambi ownership! I have a 62 and there is no visible sewer line under the belly, so my guess is that your plumbing has been modified. If you need help locating a grey water tank that fits in an non-obvious space try the very helpful people at Vintage Trailer Supply and/or incaplastics. I have bought tanks from both in the past with great success. Good luck!
Laurent
Laurent
1971 Overlander
1962 Bambi
1964 Sovereign
2003 G500
12-16-2013, 08:13 PM
1963 16' Bambi
Stevens Point
, Wisconsin
fresh water inlet
Aulden
Couldn't find the original post on the Bambi inlet.
Here's a pic of the exterior cap, it's made of bronze. The air valve was threaded into the center of the cap, I replaced it with a plumbing plug.
The fresh water tank is in the front under the dinette, while completely functional I don't use this at all. I ran a piece of half inch pex from the pump inlet and use a braided stainless hose connected to the blue water tank that sits on the ground. The water pump draws it into the system. It's seems a lot easier
than pouring water into that tube. Note folding hand truck for delivery.
12-16-2013, 08:42 PM
1961 16' Bambi
Malden
, Missouri
Thanks, Tim!
I appreciate the pics and description.
12-16-2013, 08:49 PM
1961 16' Bambi
Malden
, Missouri
Tim,
Question: what's the belly storage compartment that's open in the pic? Original to the unit or a custom creation? And how deep is it?
12-17-2013, 08:52 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Hey RC
I believe its original to the trailer. Its a curved sheet of aluminum. It has a piano hinge riveted underneath and two draw latches to keep it closed. The hatch overlays the bottom and sides. It is by no means water proof. Not very big it goes between two outriggers and as deep as the frame. Big enough for an electric cord and or a braided hose.
Need pictures?
Tim
12-18-2013, 05:26 AM
1961 16' Bambi
Malden
, Missouri
Sweet! You know me--send the pics! When I get around to the belly pan of mine, I may try to add one like that. Space is hard to come by!
12-18-2013, 06:09 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Hey RC
I believe the hatch is between the first and second outrigger. I replaced the clamps with stainless ones from VTS, they were the same as the originals.
I think it would be an easy project.
Here's some better pics.
Tim
12-18-2013, 06:53 PM
1961 16' Bambi
Malden
, Missouri
Thanks, Tim. I appreciate the first two, but I think you're just bragging with that third one! LOL Where was that taken?
12-18-2013, 08:30 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Hey RC
What a view. That was from last summer at Devils Tower NP. The NP campground not the KOA. Just wanted you to see the external tank in action.
Tim
12-19-2013, 05:27 AM
1961 16' Bambi
Malden
, Missouri
Very nice! I hadn't heard of that before, but it's in my list now for when I get to travel! Thanks for all of your help.
