Old 11-28-2009, 11:35 AM   #1
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
'61 Bambi Exterior Segments
A friend has a 61 Bambi that was crunched when a storage shed gave way do to excessive snow load.
The big question is what trailer from the early 60's would have segments that would work on the 61 Bambi? For some reason the Bambi segments are longer than those on other 60's trailers. I know some of you will cringe at the thought of using a donor to save a Bambi .
I know someone will have the answers. Feel free to chime in.
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 11-28-2009, 12:37 PM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
FYI... The 1960 to 1693 Bambi segments on the end-caps are not the same with any other end-cap segments of trailers built at that time. The front end-cap is very close, if you unrivet the bottom two segments and then cut out a wedge and rerivet the segments back together. It is very close but still not fully correct! The rear end-caps however are a "one trailer only!" To maintain higher head room the rear end-caps are not "sloped back" and are more rounder than the other larger trailers of the time! The rear window of a Bambi is also different than any other trailer of that time making the segments different too.
The best way, however very costly, is to fix the end-caps by hand. This can run up to $300 per segment, so you can see it can add up very quickly!
Good Luck!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
75th anniversary edition 19 ft. Bambi :: 2007 bambi elizabeth422 Airstream Registry Discussions 1 06-15-2014 10:35 AM
1961 BAMBI :: 1961 Airstream BAMBI SILVERSAILOR Airstream Registry Discussions 0 08-19-2011 08:31 AM
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
