Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1961 - 1963 Bambi
Old 06-25-2012, 05:40 AM   #1
1971 27' Overlander
1962 Bambi - Refrigerator
I just purchased a 1962 Bambi that is in great condition. I removed the fridge and need to replace it. I believe it is the original one....Dometic MC 16, gas only! Does anybody know what option(s) I have to replace it, gas and electric (110V).
Thanks!
Laurent
1971 Overlander
1962 Bambi
1964 Sovereign
2003 G500
lmassa is offline   Reply With Quote
Old 06-25-2012, 06:50 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
There is a dometic replacement chart that may help
http://www.google.com/url?sa=t&rct=j...SSC6c0f09fXB0Q
If that super long link doesn't work just search for Dometic replacement chart.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
RickDavis is offline   Reply With Quote
Old 06-26-2012, 01:13 AM   #3
alclad's Avatar
1961 16' Bambi
Las Cruces , New Mexico
Images: 46
we use this one:
N300/N302
works great on gas,ac,dc....
alclad is offline   Reply With Quote
Old 06-26-2012, 05:27 PM   #4
1971 27' Overlander
Thanks Rick. This was very helpful. Another member has a replacement fridge that he is not using, so I will be buying it! Case closed...on to the next!
Laurent
1971 Overlander
1962 Bambi
1964 Sovereign
2003 G500
Old 06-26-2012, 05:28 PM   #5
1971 27' Overlander
Thanks for the info. Looks like it is taller than mine by 7 inches...Do you have the stove on top of yours?
Laurent
1971 Overlander
1962 Bambi
1964 Sovereign
2003 G500
Old 09-22-2013, 11:37 PM   #6
longmont , Colorado
Did you have to cut vent holes in floor? I read where newer refers require more heat venting.....my Bambi has a solid access door in rear although I see some with a vented/louvered rear access door...
jimshaner@ms is offline   Reply With Quote
Old 09-24-2013, 07:15 AM   #7
1971 27' Overlander
I didn't cut vent holes in the floor. May be I should....I have used it on 110V already and there was no heating problem. I am not really planning to use it on LP. Cutting vents shouldn't be that difficult and now that you brought it up, I think I will, It can't hurt....
Laurent
Laurent
1971 Overlander
1962 Bambi
1964 Sovereign
2003 G500
1962, 1962 bambi
