Old 04-04-2019, 08:09 PM   #57
1982 24' Airstream 240
Reno , Nevada
Rob, I'll get you some oscilloscope traces tomorrow. But, one thing I need to note here is my experiments with the flow sensor packaged with the Zemco carburetor units. As you probably know, the sensor is essentially an optical isolation switch with a rotating interrupter. The lower part of the optical stage of the sensor is just a continually on 12v GE161 incandescent light. This light is focussed with a lens to a channel that bisects the raceway channel with the opaque circulating ball driven by the gasoline flow. On the other side of the light channel, there is another lens focussing the light on a photocell. The output of the photocell is the input to the Zemco unit. I found no voltage output at the photocell terminals. Instead, the resistance with the light on and an uninterrupted channel was 0-2.2 ohms. Interrupt, the resistance was greater than 10,000 ohms. Running, you see a on-off switch (nice square wave) the frequency of which varies with the flow rate. Hope this helps, more data tomorrow!
FrankGRUN is offline   Reply With Quote
Old 04-05-2019, 07:23 AM   #58
Magnet18's Avatar
Churubusco , Indiana
Thanks Frank!
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 04-06-2019, 09:00 AM   #59
Speed sensor is now attached. I can't install the magnets until I raise the rear wheels off the ground so I can rotate the drive shaft. Maybe later this week.
Old 04-06-2019, 11:08 AM   #60
Looking good Brad, altho the sensor might need to be closer to the magnets.
Old 04-06-2019, 12:01 PM   #61
No, right on spec. Per the instructions the head of the sensor is supposed to be 5/8" from the drive shaft. The magnets supposedly are 3/8" overall which leaves a gap of 1/8" to the drive shaft.
Old 04-06-2019, 01:14 PM   #62
Ok, I stand corrected. Seems my memory is failing!
Here is my collection, and I am sure I have a couple more, even tho I sent one or two to Magnet!
4x ZT4ís, and 2x DCS320ís, one of which is the EFI version that I sent the EFI unit to Magnet to copy.
I also have a ZT5, which is similar to the ZT4, but has an LCD display. Thatís the one I am installing in my Motorhome
In the non EFI box, there it is.... the installation manual with the EFI installation!
Old 04-07-2019, 04:50 PM   #63
Reno , Nevada
Oscilloscope Data
OK, Rob, time for a bit of a data transfer. I'm enclosing several traces from the Fuel Injector signal from a 1996 Jeep 4.0L. Engine control provides OBDII data and no check engine light is triggered wiring these measurements. Since I didn't think you needed really close profiles of the signal waveform, I'm including scans 10V per division on the y-axis and from 1 to 50 ms. per division on the x-axis. If you need other scales, let me know.
But as always, following data there is more data and a question. After I tapped the Fuel Injector circuit, I add several different 12V LED diode bulbs (contained purpose built drivers) in parallel with the Fuel Injector Solenoid, much as we will be doing with the adapter. All functioned, but the higher output ones triggered the check engine light. Both OBDI (the system delivered with our target injected vehicles) and the current OBDII systems have check engine lights and depending on the triggered code, there may be a response of the engine ECU changing the operating parameters of the engine tune. I think it's important to make certain that the addition of the adapter box have no impact on the PCM operating the injectors.
In my LED experiments, I tried 3 different LEDs all compatible with 12V. The first and most powerful (61 lumens) had a measured DC resistance of 198 K Ohms and drew 39 milliamps when connected to 14.5 V. When connected across the fuel injector, this bulb triggered the check engine light.
The second trial used a multiple SMD LEDs, indicated 9 M Ohm and drew 60 milliamps connected to the 14.5V source. It also triggered the Check Engine Light.
The third LED was a single SMD chip, with embedded driver I could not measure the cross-terminal resistance, only that it was in excess of 25 M Ohms. It drew 14 milliamps connected across 14.5V. This one and several other instrument lights I had on hand did NOT trigger the Check Engine light! I conclude that current draw is the important parameter (less than 0.014 amps and resistance/impedance must be greater than 10 M Ohms.
Hope this helps!
Old 04-08-2019, 08:08 AM   #64
Magnet18's Avatar
Thanks for posting the instructions Steve!
Thanks for the scope traces Frank
Your resistance and current values don't pass the V=IR giggle test, 14.5/198000 should be 73 microamps, 3 orders of magnitude less than your measured current. Reversing it, 14.5/.039= 371 ohms, the actual resistance of your first LED when turned on in situ
LEDs have much higher turn on voltages than normal diodes, so you probably measured it in it's off state as a normal DMM won't turn it on
Your jeep 4.0 injector should be 10.8 ohms minimum. Anything more than 10K resistance should be completely within the noise of the injector resistance measurement (10K would be 1.45mA, and 10K in parallel with 10.8 makes.... 10.79)
-Rob
Old 04-08-2019, 08:01 PM   #65
Reno , Nevada
Parallel Resistance Tests
As suggested by Rob, I connected a series of different fixed resistances in parallel with the Jeep fuel injector and looked for the triggering of the check engine light. Started with 47K Ohms and continued through 10K Ohms down to 47 Ohms. None of these triggered the check engine light. I then tested (wired in parallel) a series of LED bulbs that were not polarity sensitive (assume they have imbedded driver circuits) and all triggered the check engine light. I then tested a set of LEDs that consisted of an LED diode and a dropping resistor (package is polarity sensitive) for use at 12V. None of these triggered the check engine light. It appears the issue is in the driver circuit of the more powerful LED's as the 47 Ohm resistor draws more current than any of the LEDs tested.
Old 04-12-2019, 06:13 AM   #66
This is the Zemco unit Iím planning to install on my Motorhome. I called it a ZT5 but not sure thatís correct. Either way, itís the only one like it Iíve ever seen.
Old 04-12-2019, 09:01 PM   #67
Reno , Nevada
I have never seen one like that before. I'm mounting the ZT-3, and I just picked up another old stock NIB unit complete for $20.54, shipped! So now several additional spares. Wish I could find one like yours. Must be one of the very last designs!
Old 04-12-2019, 09:55 PM   #68
2016 26' Flying Cloud
Southlake , Texas
Itís been years since I have thought of Zemco. I used to own an auto shop and we actually sold Zemco computers. I installed one on my Jeep Cherokee and it was a fun toy, but actually pretty accurate. I say pretty accurate only because my faith in its accuracy left my family and I stranded between Capulin and Raton, NM in the dead of winter. My wife wanted to stop in Dalhart to get gas, but I insisted that we could make it to Raton with 20 miles to spare according to the trusty Zemco. WRONG! This is one of the most desolate stretches of highway anywhere in the lower 48. We could see Raton as we sat beside the highway, but I was in a bit of a quandary. I didnít feel it was safe to leave my wife and 3year old son in the car while I went for gas and it was too cold for our son to be in the elements. Luckily, it wasnít too long before some guys in a stakebed truck came along looking for the driveshaft they had lost the day before. And, they had a full gas can on their truck. MORAL: The wife is almost always right!
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 04-16-2019, 02:14 PM   #69
Magnet18's Avatar
I recieved notification the boards have shipped!
I've gotten distracted by homework and other projects, so I haven't ordered the BOM yet. I'll try to sit down and do that tonight. I also recently finished dropping the engine into my 86 4runner but haven't turned it over yet, and I'm itching to do that, so no promises.
-Rob
Old 04-17-2019, 03:39 PM   #70
Reno , Nevada
The engine for the 4Runner, original or? Fuel injected??
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
Travel Computers jcanavera Off Topic Forum 4 09-02-2004 11:00 AM
Information about computers (Cases, Laptops & More) 53flyingcloud Off Topic Forum 59 04-03-2004 05:46 AM
Different Looks on Different Computers COArgosy78 Forum Admin, News and Member Account Info 3 09-20-2003 02:38 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
