Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-30-2008, 06:38 PM   #1
kmamedia's Avatar
Profile:  Seabrook , Texas
Workhorse P32 Ignition Switch
My Ignition switch, on the sterring colum burned out twiced in 6 years. I know there is a upgrade kit for it, but does it work? Workhorse plames AS,
AS plames workhorse. Anybody have a solution
kmamedia is offline   Reply With Quote
Old 11-30-2008, 10:18 PM   #2
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Yes
Hi, my brother has an SOB class A motorhome on a Workhorse chassis; He had the same problem, and the fix is an updated ignition switch, an updated pigtail/wire harness/connector, and most importantly a relay to carry the load. The relay carries the load, that in time, overloads the ignition switch and it's connector. So if you just replace the switch and/or the connector, you didn't fix the problem. [RELAY]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 12-01-2008, 01:19 PM   #3
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
GM/Workhorse
Contact a GM store that is an authorized Workhorse repair facility. They should be able to supply the parts and do the up-grade.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 12-02-2008, 02:03 PM   #4
kmamedia's Avatar
Finally got a hold of Workhorse, they said its the AC blower motor, that the body builder hooks up to the ignition. The switch is rated at 40amps and the blower draws 30 when it is running on high.
2005 LY Workhorse Alternator museumdude Mechanics Corner - Engines, Transmission & More... 8 12-04-2008 03:23 PM
Workhorse brake rotors harold1946 Land Yacht/Legacy Motorhomes 8 07-09-2008 08:49 PM
Ignition Switch For '61 Bambi Lauerman Refrigerators 2 03-16-2008 10:21 PM
Headlights 'ON' ignition switch buzzer Astrodokk Airstream Motorhome Forums 1 11-16-2003 06:11 PM
New P-3X series Workhorse Chassis evan Airstream Motorhome Forums 6 04-19-2003 09:00 PM
