Originally posted by wb13798
peter why did you inslall a switch on your pump?? what made you do it. instead of on full time ??
al
I iniatially installed the rear fuel pump for starting. To get the big 454 going, I always had to crank 3-4 times. (A sure way to kill your starter) Now I flip the switch til pressure builds up, depress the gas pedal 2-3 times and it fires the first time.
I discovered the trip saving side benefit when climbing 10k' passes.
The other reason is that I didn't want to go thru the trouble of wiring it to oil pressure or any other safety cut-off device.
The determining factor was full pass-thru of the electr. fuel pump in off position.
You may have read my posts about the fuel filter issues connected with the rear fuel pump. I ended up moving the canister type filter in the middle of the coach to the rear, before the elctr. fuel pump.
You mentioned a carb from Auto Zone. Was it a rebuild? I pretty much killed a GM400 motor with one of those before.
Threw it away and put an Edelbrock in.
Now I am running an Edelbrock on the 454 as well.
