Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 05-18-2006, 04:40 PM   #29
outofcontrol's Avatar
Profile:  Portland , Oregon
Pimp My Ride!
From the PO, we started with a pretty good coach:
Things he updated/repaired/upgraded:
1. new water heater
2. painted inside (great job, he's in the business)
3. new floors (again, they look great)
4. new front carpets
5. new tires
6. re-built tranny
Things I have done/am doing
1. new front air bags
2. added air compressor + leveling system
3. new shocks all around
4. fixing front brakes
5. re-built heater core
6. new 12V water pump
***Wish List***
1. Transplant 2005 Dodge Cummins TD with OD $10,000 (est)
2. New (quieter) propane or diesel gen $3000
3. Carrier Low Profile (7.5") roof-top AC units $700 ea.
4. Polish skin to mirror finish - 200hrs
5. New Remco RV mirrors $400 set.
I figure the '81 454 will give up the ghost some day around 90-100k miles. We just turned 60k; so by the time we need a new motor (4-5 years), there will be plenty of used diesels around. The new diesels are just getting to the point where they are almost as quiet as a gasser, but so much more power, efficiency, and durability.
If I spend $15,000 on this RV, and make it super fun, I'm still waaaaaay better off than spending $100,000 on a new unit. And it's so much cooler!
-Kevin
1981 Airstream Excella 28' MoHo
outofcontrol is offline   Reply With Quote
Old 05-18-2006, 06:11 PM   #30
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
I still want one
I realized this week that my vintage AS will be an early 90s 28' to 31' (280 & 310?) turbo diesel motorhome. I'm starting the research and firming up the vision. The cash will be there when the vision materializes.
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 05-19-2006, 03:43 PM   #31
wanderingeye's Avatar
Profile:  Skaneateles , New York
wish list/ cost
Kevin Et Al I used some very rough numbers to satisfy myself that our Classic MH was the best buy for our intended use...20,000 miles for five years. When compared to anything built on a Sprinter chassis and it,s cost of ownership and operation (3.00fuel) the AS will cost .47 cents per mile, while the sprinter will cost .92 cents per mile. The power to wieght ratio between our 27 and a sprinter MH are at least similar and because of the relatively small size we have not yet needed a "towed". The wish list of course will change the equation but for the first 4000 miles it has run like a top. Cheers Tom
wanderingeye is offline   Reply With Quote
Old 06-09-2007, 04:48 PM   #32
Profile:
Clear Coat
Can You Clear Coat A Painted M.h.? About What Would It Run. I'm In N.c.
Is That A Good Idea?
Thanks For Any Replys
gallion is offline   Reply With Quote
Pingbacks are On
SEO by vBSEO 3.1.0
