Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-15-2006, 05:08 PM   #1
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
Hello Is The Doorbell Ringing?
Okay, we have the 345 so it may not be the same, but our doorbell is under the couch on the road side. It isn't very loud and I think I would have to pull the couch out to work on it. Our couch is right behind the drivers seat. I don't know how yours is set up. Good Luck!!!
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 01-15-2006, 06:59 PM   #2
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Doorbell thread.
http://www.airforums.com/forum...ese-16223.html
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 07-17-2009, 10:13 AM   #3
454 310! Yea!!!
MaryContrary's Avatar
Profile:  on the road , California
Images: 27
I've had my '84 310 for count 'em ..3 whole months!
everything needed overhaul...
-window seals, thankfully no major leaks
-fixed gasket and full replacement of passenger side windshield
-new velvac mirrors
-antique plates
-all new hoses and wiring with heat protection under doghouse
-new fridge
-genny overhaul and tune
-ac charge, new ducts, wiring
-all new fuses everywhere..whew!
-dealt with the ghosts in the fuse panel and under dash spaghetti monster
thanks again to Brad for all the 310 manuals
-retroteck throttle body FI she purrs like a wild cat now & starts every time!
-new rear fuel pump with wiring job that almost killed us fixed and replaced whole fuel line and return
-complete new exhaust pipes / muffler with pretty chrome tips
-ripped out old CA smog stuff and excess vacuum lines
-doghouse dynomat insulation
-new shower head and hose
-all LP lines checked
-hot water heater works
-all new plugs and wires
-swap front couch with my other '82 a/s trailer the upholstery is much nicer, and the whole thing is MUCH sturdier... and what is that long heavy table that is hidden under the original couch? it would have blocked the whole front area... what were they thinking?
-all new draperies and curtain rods
-replaced thousands of little screws and rivets all over coach, no more rattling down the road
-pulled out about 300lbs of excess woodpanneling interior ugly stuff including side front chairs, folding doors, plastic excess etc.
-new running lights all over that still dont work properly
-new double coin tires all around
-alignment
-full break check with tires off
-new front airbags, checked back they seem ok
-new airbag compressor
-sandblasted and painted rusted out under compartments
-new 500lb slides and underbelly reinforcement weld on battery box
-3 new batteries
-checked and refitted frame ground
-peeled off old woodgrain stripe
-removed all rotted cracked exterior trim, must call Andy's RV to get lower black replacement
-removed double twins in rear threw up a cross support over holding tanks and now have a huge king mattress in rear. with tons of extra storage.
-led 1156 bulbs all around...check ebay for 1156 LED...something like 10.50$ for 2,
500,000 hours, and 200% more efficient
-all new air / fuel / water filters
-thankfully no leaks in water system, new water canister filter
-fixed awnings all round
-deer warning system
-new potable hose
-new horn
-fixed all turn lights, want to replace with led and add extra breaking lights in back
-going thru "whats in your toolbox" and "454 tune" threads & have extra ignition module, fan clutch, distro coil, spark wires
-flushed radiator, new cap
-replaced gaskets all over
-dude, my vacuum step, and deadbolt lock from dash works! i dont know about that silly doorbell
-fixed hinge pin in door
i'll get around to wood flooring, and remaking doghouse, must remember to not freak out on the dash guides and warninglights.
new carpeting in driving area
and new low profile a.c in front after this one dies
new brass kitchen and bath fixtures/ facuets
hopefully new sinks and potty
and wanna pull out 2nd ac in rear and put in fantastic fan or skylight, i dont need 2 temperamental acs to pull on the genny
when it cools off this winter polish exterior and completely redo floorplan. remove old outdated antenna and all the excess stuff on roof. reseal Vulcum all over
get solar panels and system up and running with all that added roof space
unfortunately there is some bad endcap dents in rear...super costly to fix and why the initial investment was so low, so that is why we can violently hurl money at her right now. She sat in the same storage for over 15 years, but was thankfully started and ran every month.
i am a slave to this beauty.
I love her so much I'd polish her 4x over with a toothbrush and love every minute. i get the warm fuzzy feeling just thinking of her.
i read this forum like a bible, and cannot thank you guys enough for this information...
we are working full time to get her reliable. this forum is invaluable!
  • 1984 310 Limited Motorhome
The moon of a bright silver, which dazzles by its shining, illumines a world which surely is no longer ours; for it resembles in nothing what may be seen in other lands.
-pierre loti
MaryContrary is offline   Reply With Quote
Old 07-19-2009, 07:40 PM   #4
Profile:  Richmond , Kentucky
Did you have to replace the bottom plastic tracks and if so what did you use?
-new velvac mirrors
Would you mind posting pictures of your mirror installation? I have new velvac mirrors but haven't had the time to install them as yet.
Glad to help!
What table under the couch?
No doubt running lights can be extremely frustrating. I've fought them and continue to fight them.
I hope you have better luck with those tires than we did. We ended up having ours checked at another shop and found that all of them were out of round. We managed to get the shop we bought them from to refund our money. The ride was horrible until we switched to toyo tires. Much better ride.
This is something I have to do as well.
Pictures please!
Did you rework the ground connection at the left rear of the motorhome, on the underside of of the motorhome near the water tank area?
Again, pictures please!!!!
Lots of good threads on this subject.
I recently got our vacuum steps to work as well. Had to replace the switch in the door and then fix all the vacuum lines. Steps work well now. The door lock is another issue. When you flip the switch you can see the handle try and move but there appears to be some kind of binding taking place inside the wall. I also can't get the dead bolt to lock with the key (it is the right key). I would have to remove the wall next to the door to get to the lock mechanism. Some day.......
Any chance that you could provide a description of what you did? I'm faced with either replacing the hinges or fixing the pins somehow.
There are some good threads on dent removal. We have a few to fix ourselves.
Yep, lots of good info on these forums. I would encourage you to post about all of our experiences as well, who knows who you will help someday by doing that.
"Wherever you go... there you are." - Buckaroo Banzai
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 07-22-2009, 11:50 PM   #5
454 310! Yea!!!
Images: 27
i am gonna go grab my camera again tomorrow but....
here's that silly table, and where it was kept
sorry the pics are so big...as big as that table!
i'll get some pics of the mirrors too, we had to rip out the whole interior to find the faceplate & of course nothing lined up, so we just placed them where the rear view seemed optimal..i dont have the super-duper heated/signal ones so they did not have to be wired up. i'd give anything for the chrome ones tho, the bulky black plastic seems just wrong on this vehicle
i just got an alignment, and they said the double coin tires were fine but this is something i will look out for. I'll check them out again before the warranty is up.
i wish i had gotten before and after pics of the battery box, crazy enough the PO but a wooden board there and the batteries fell thru dragging and bending the whole box and slides a few feet, hence why i had to check the wires and re attach the ground to the frame by the water heater and also checked the back after finding that my new rear fuel pump wouldent work, but hummed right away after fixing the ground
it looks great now, mcmaster carr has the 500lb shock weight slides, but we just ordered them from our local airstream guy, i think they had to custom make them.
as for the back bedroom i just wont mess with rearranging 25 y.o. plumbing and watertanks...if it's not leaking now i'll check it and leave it all safely under the bed just as it was...no monsters under there...yet!
it was fun trying to get the huge matress in the door, but all in all i just put up some plywood cross supports and voila!... from twins to king!
what is up with the door? it seems like it twists everything on the hinges upwards everytime it opens...and the pin creaps up and up till the door wants to fall off
i'm searching the exterior forum for a proper fix, but a bolt with nut seems to do the trick
there was ALOT of gunk and dirt around the hinges, door and locks, i also am having upper lock problems, me thinks that the top lock interior handle thingie is just always been kind of a weak component, and i have to be very gentle with it, just like the locking lever on the bottom lock. it was so crusted with grease and dirt i had to take apart the whole mechanism and clean it to get it to lock from the inside.
i'm not sure where to post them, so i'll post em here...
here are some pics of redoing the insulation in the doghouse, i used dynamat and dynamat hoodliner for hi temp soundproofing..sooo much quieter and no blasts of heat when driving
i had found some random wide rubber strip and it seems to make a nice seal around the edges. the hoodliner is peel and stick,
and hurray for lots of silver tape!
-pierre loti
Old 07-25-2009, 10:49 AM   #6
Thanks for the photos. Our 310 didn't come with a table like that, it has a small dinette on the passenger side. I'll have to check to see if the pockets are in the floor under the carpet.
Somewhere on the internet I've seen pictures of someone that mounted Velvac mirrors on their coach. I have the "super-duper heated/signal ones" . Got them off ebay. It means I have to tear into the interior walls but having the ability to adjust them from inside the coach will be nice. Like yours ours are black. Just couldn't justify the extra bucks for the shiney ones.
If you're not getting vibrations from them while driving now then you should be ok. The vibrations were noticable on ours right after installation. It made a 2400 mile round trip a miserable one.
The bottom of our battery box is rusted out as well and wood is holding the batteries in place. Guess its time to do something about that! Fortunately the slides are in good shape.
Looking forward to the pictures!
Something is definitely twisted. Ours sticks out some at the bottom. There are fixes for this, one of which is to remove the rivets from the lower inside skin, reshape the door and rivet the inner skins back on. This is supposed to help it hold the new shape. I'm going to replace our hinges because of sloppiness in the hinge pins themselves.
I plan on replacing the insulation eventually but ours still is in reasonable condition and works pretty good.
