Old 06-13-2004, 04:07 PM   #1
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
window lip seal
what is the recommended way to glue this to the window frame??? i seem to have glued to the window also.. not the intended results. made a mess. again////
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 06-13-2004, 05:33 PM   #2
I recently resealed all of the windows and door in my International. My best results:
1) Clean gasket area window frame down to bare aluminum. Finish with 00 steel wool.
2) Cut the gasket about 1 inch longer than needed.
3) Study the gasket to insure that when the gasket base is installed, the 2 (flares)
lean away from the glass.
4) Using my finger, I put a thin, but uniform film of 3M adhesive on the gasket
base, and set it aside.
5) Now using the same technique, put a thin film of adhesive on the frame where the
gasket base goes. Avoid getting adhesive on the frame portion that
is perpendicular to the glass.
5A) Check all surfaces for proper adhesive coverage.
6) Start at the bottom center of the frame and apply the seal.
7) When the seal is wrapped all around, overlap the 2 ends.
8) Take a new razor and make a neat cut in the middle of the overlap
9) Remove the overlaps, glue the ends together, and close the window against
the female portion of the window that you had previously covered with wax paper
or polyethylene film, or silicone.
Hope this helps,
Dick
Navigator is offline   Reply With Quote
Window Seal niftypkg Windows & Screens 15 03-10-2018 05:48 AM
Vertical Lip Seal Inland RV Center, In General Motorhome Topics 0 01-19-2004 02:09 PM
Window Doesn't Seal carls017 Our Community 4 10-06-2003 12:17 PM
Report of window replacement in 1977 Minuet 6.0 kenny All Argosy Trailers 2 08-27-2003 07:11 AM
