Old 06-01-2014, 06:41 PM   #1
Fort Lauderdale , Florida
Whining Noise
I test drove a used 2013 Airstream Interstate with 10500 miles on the odometer. When accelerating, the van made strange whining noises for a second or two. Is this normal? Maybe the turbo kicking in or could it be the driveshaft? I like to know if there might be a problem before I make an offer.
Thanks, Gerhard
gerhard is offline   Reply With Quote
Old 06-01-2014, 07:56 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Hard to say without actually hearing this sound. I do sometimes notice the turbo whine when accelerating. To be sure you will have to have it checked by a mechanic that knows Sprinters.
- - Mike
Old 06-01-2014, 08:13 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There are so many possibilities…
Where does the noise seem to be coming from? Engine compartment? Under the aisle floor? Differential? One corner?
When you take it to your Sprinter dealer for service, get a technician to ride along with you, so you can point out the noise to him. Dollars to donuts, even though you can spot the noise every time you hear it, the technician won't pick it up the one time he hears it, without someone pointing it out to him.
Cats and ultraleather Airstream upholstery don't mix!
Old 06-02-2014, 06:34 AM   #4
Gainesville , Florida
On the older models if the turbo resonator was replaced you could more easily hear the turbo whine. Replaced with the aluminum one which did not crack like the stock ones did. Gear heads love to here the turbo whine! Jim
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
high pitch whining noise.. safari25-05 Tow Vehicles 13 03-21-2008 07:39 PM
My trailer is whining! thecatsandi Batteries, Univolts, Converters & Inverters 7 01-03-2008 09:35 AM
Dining and whining? Amy in an Argosy The Pet Forum 21 03-02-2004 06:01 PM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
