Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-26-2006, 03:33 PM   #1
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Where's the air compressor on a 270 MH
I'll get a new member started off quickly. Tom's new-to-him 270 has a bad air compressor. It's not the fuse. The compressor itself died.
Can a 270 owner out there tell him where the rear air bag compressor is?
Any tips on where to find a new air compressor?
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 01-26-2006, 03:54 PM   #2
davidh
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
I use to be a heavy truck mechanic and got the oner to work on a few motor homes, dose it have air breaks if so it would be on the motor if not I dont have a clue not being able to look at it, but you can always crawl under and follow the air lines to the general area of compressor or talk to a service manager at a dealer. hope this can be of some help..
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 01-26-2006, 04:08 PM   #3
davidh
1977 31' Sovereign
davidh's Avatar
re aircompressor if you have air brakes on your rig its not a compressor problem its more than likely your suspension air ride self levaling valve, that would be located some where derrectly over your rear drive axle it wll have three air lines running to it and there will be a steel rod on a lever mounted to the valve then from there the rod mounts to the axle. if this is your case get ahod of me and I will explain how to check it...
Old 01-26-2006, 04:35 PM   #4
shadejo
Profile:  Ottawa , Ontario
I believe he is looking for the location of the electric air compressor that provides air for the suspension. On the 345 I have it is in a corner cupboard in the bedroom.
I presume he is looking for information on where it is in the smaller unit....
John
shadejo is offline   Reply With Quote
Old 01-26-2006, 04:52 PM   #5
cooperhawk
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
I can hear it in the cornor cupboard in the bedroom, but when I open the door, I can't see it. How does one access it?
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 01-26-2006, 05:22 PM   #6
2airishuman
2airishuman's Avatar
Profile:
compressor in my old air moho was in the generator compartment rear/curbside.
outside access, mounted just aft of the onan as i recall.
if the air compressor dies, one can still inflate rear bags. there is canister with a schrader valve stem down under and a regular tire inflation hose can be applied at this site.
of course my moho had lots of odd things, as do i.
cheers
2air'
Old 01-26-2006, 06:27 PM   #7
wanderingeye
wanderingeye's Avatar
Profile:  Skaneateles , New York
David Thank you. We had a foot of snow today and the overnight low will be 8F. With your description in mind I will be out under the coach tomorrow morning. Regards Tom
wanderingeye is offline   Reply With Quote
Old 01-26-2006, 07:12 PM   #8
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Tom,
Welcome! You might consider looking at a replacement from harbor freight or even JCWhitney. Even on the 345's they are not very powerful units.
Jim, Don't know if you have a rear queen layout like mine, but there is a small shelf between the bed and the rear wall. There are a few screws holding it down. Under this panel you'll find the compressor and the water pump.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 01-26-2006, 07:31 PM   #9
1985air345
1985air345's Avatar
wanderingeye is the proud new owner of Exhibit "B":
http://www.airstreammotorhomes.com/1984/1984_270_B.html
His trip home was eventful but smooth in comparison to others! (ok, maybe smooth was a bad word to use when he had a leaky air bag suspension )
Fred H.
Old 01-26-2006, 08:00 PM   #10
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
On my 310, it is located in the driver side aft compartment which also holds the reel for the 30 amp power cord.
1984 310 Limited Motorhome
guy99 is online now   Reply With Quote
Old 01-26-2006, 08:05 PM   #11
guy99
guy99's Avatar
Images: 16
This thread has information on parts and rebuilds for these compressors.
http://www.airforums.com/forum...sor-19711.html
Old 01-29-2006, 08:03 PM   #12
wanderingeye
David Useing your information I found and understand all the parts of the ride leveling system. Thank you for the help. Tom
Old 01-29-2006, 08:12 PM   #13
wanderingeye
Fred Profound thanks for the help you have given me. Exhibit B is safely in storage until spring. This a/s m/o is 80% of new and I intend on bringing it to 100% I'll have the ride leveling air pump out and rebuilt next week. Tom
Old 04-19-2006, 06:35 PM   #14
Whipsas270
Whipsas270's Avatar
Profile:  Benbrook , Texas
air compressor on 270
I have a 1984 AS 270 the air compressor has its own compartment aft of the entry door needs a key to open it where as the basement storage just has turn locks.
Whipsas270 is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-09-2005 03:53 PM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 08:12 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 08:45 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 10:33 AM
Ram air Kit rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 10:04 AM
