Old 08-06-2005, 12:13 PM   #15
Tinsel Loaf's Avatar
Short out the low oil switch and run the gen so you can eleminate that as a problem.
Tinsel Loaf is offline   Reply With Quote
Old 08-06-2005, 02:46 PM   #16
2006 30' Classic
Farmington , New Mexico
Images: 14
swebster-----here's a thought that will only take a minute to check. As george mentioned the point type ignition uses a resister to lower voltage to the points to keep them from burning up. While the engine is being cranked 12 volts is applied directly to the points and ignition system providing a higher voltage to the coil and thus higher voltage to the spark plug during cranking for starting purposes . When the engine starts and the start switch is released the ignition current is directed through a resistance unit to reduce the voltage and extend point life. That said it is possable to have a fouled or partially fouled spark plug that will fire when in the crank position and has the higher voltage applied then when the switch is released and the lower voltage is applied there may not be sufficient voltage to fire the plug. Just a thought but sometimes the simplest things are over looked.-----Pieman
Mike Lewis is offline   Reply With Quote
Old 08-06-2005, 03:00 PM   #17
2006 30' Classic
Images: 14
swebster----as to "shorting out the oil presure switch". To properly by-pass that switch you must determine if it is a normally open or normally closed switch. As rule of thumb a switch with a single wire is normally closed and one with 2 wires normally open. I both cases these switches a generally by passed during cranking and then become functional when the ignition in in the run position thus it would exhibit the condition you describe if it is defective. To test a normally closed switch <one wire> just unplug the the single wire from the switch and try it. To by pass a normally open switch < two wire> unplug the switch and jumper across the wire end connector and try it. Sometimes locating the switch is the hardest part of this job.
Pieman
Old 08-12-2005, 12:52 PM   #18
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Pieman,
Thanks....this was an old post. It turned out to be my Oil Pressure switch. Replaced it and the GenSet has been purring for almost two years now.
Also, noticed at the same time some chaffed wires in the control box which I'm sure caused the original R1 burnout.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 09-17-2018, 10:07 AM   #19
tacoma , Washington
resistor
ok the resistor in mine is screwed to the side wall just behind the start switch next thing is im searching for a resistor part# 304-0735. any one got a clue where i could get my hands on one.?
wiytboi is offline   Reply With Quote
Old 09-17-2018, 12:27 PM   #20
I see you are new, so
you might want to check the date of the post you are replying to as
alot of things happen in FIFTEEN YEARS!
George is offline   Reply With Quote
Old 09-17-2018, 03:16 PM   #21
tacoma , Washington
Haha your probably right about that.. Thank you.
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Onan Generator 87MH Mechanics Corner - Engines, Transmission & More... 34 07-10-2007 07:26 AM
Help! Resistor on fan switch Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 22 12-20-2003 08:01 AM
Onan 4k 1979 Oil Filter? RichardT Mechanics Corner - Engines, Transmission & More... 2 09-28-2003 07:50 AM
onan troubleshooting help rcaldwel Generators & Solar Power 2 03-10-2003 05:00 PM
