Old 08-27-2015, 02:17 AM   #1
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
Where is the calorstat ?
Hello. I am looking for the calorstat ( I don't know if it is the good name in english = thermostat for regulation of water temperature ) on the 454 ???
bigbidule is offline   Reply With Quote
Old 08-27-2015, 02:51 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The thermostat should be located in the thermostat housing at the engine end of the upper radiator hose.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 08-29-2015, 12:50 AM   #3
bigbidule's Avatar
It is in a case ? Is somebody knows the part number ? Is there few gap of temperature available and which one is the best ? Thank you. Marc
Old 08-29-2015, 03:33 AM   #4
Well Preserved
1993 21' Sovereign
It is available in 160, 180, and 195 degree temperatures.
Which one you need depends on what application it is needed for.
Old 08-30-2015, 08:58 AM   #5
bigbidule's Avatar
I live in a tempered country ( 30C in summer, - 10C maximum in winter....) so ?
Old 09-07-2015, 09:49 AM   #6
bigbidule's Avatar
....so, I think the good one is 195F . No ? Please can you give me some informations about model or mark ? Thank you. Marc
Old 09-07-2015, 10:43 AM   #7
1981 31' Excella II
New Market , Alabama
Pull the old one out and see what it says. Typically, a non fuel injected engine would use a 180 degree thermostat. Pollution control required higher water temperatures to work well. Pull the old one out and it should have the temperature in degrees F that it is designed to open at. Stant makes a good thermostat. Any online autoparts dealer in the US should be able to get you one.
Perry
Old 09-08-2015, 12:48 AM   #8
bigbidule's Avatar
Ouf, the part numbers list of Stant is... a little bit long. I think my only solution is to pull out the thermostat ........
Old 09-08-2015, 05:59 AM   #9
1981 31' Excella II
In the USA all you do is tell them the year it was built and the engine size and what temperature you want and they just bring you one. I am sure you can order from places like.
http://www.summitracing.com/parts/sn...make/chevrolet
Advance Auto Parts: Car, Engine, Batteries, Brakes, Replacement, Performance & Accessories
AutoZone | Auto Parts & Accessories | Repair Guides & More
Perry
Old 09-09-2015, 12:18 AM   #10
bigbidule's Avatar
I don't find Chevrolet-P30-1980
(is the same as G30 or something else ? )
is somebody can look for me the right item please, I am not sure understand all... ( 180F ) ?
Thank you
Old 09-18-2015, 07:18 AM   #11
bigbidule's Avatar
Motor of my excella does't rise in temp. . Normally, on road , the gauge is about 120/140. In hard road (mountain road ) maximum is 160...
And the heating is ridiculous !
The thermostat is a 160 . Is it normal for a tempered country ?
Or gauge is false ? Where is the water temp sensor ? How can I test it ?
Thank you
Old 09-20-2015, 09:51 AM   #12
1981 31' Excella II
The temp sensor is the thermostat on something this old. You might try a hand held IR thermometer aimed at the radiator. A thermocouple and remote gauge would be ideal.
Perry
Old 09-21-2015, 01:22 AM   #13
bigbidule's Avatar
I am waiting for a new sensor and a new 180 thermostat.... I hope the sensor will be the good one
Old 09-21-2015, 11:05 AM   #14
1981 31' Excella II
Most factory gages are indicator only and are not accurate. They give you a relative indication. You can calibrate it with some sort of temperature gage. Even a bulb thermometer stuck into the radiator cap opening will work. Make sure you don't scald yourself though when removing the radiator cap.
Perry
