Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-31-2003, 11:13 AM   #1
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Wheel nut torque on aluminum wheels
Does anyone have the specs for lug nut torque on 6 stud alloy wheels? I have installed new tires on 15 inch, newer (1989) rims, on my 67 Globetrotter but think the 100 ft\lbs the tire store is too much. Thanks. Tom
Tom Nugler is online now   Reply With Quote
Old 08-31-2003, 11:39 AM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Whay style lugs? Does the rims have steel inserts?
A tapered lug with no instert is going to be around 100 and RECHECK in the first 100 miles or sooner,
A flat style washer 120 is not unheard of. Cone styel insert will be around 90.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-31-2003, 04:44 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Perhaps not an identical situation, but my factory alloy wheels call for 100ft/lbs in the shop manual for my Impala SS. Toaster is right, it's not uncommon to have the lugs at or beyond 100 ft/lbs. Check with the manufac of the rims to be sure and get a good torque wrench!
Eric
Old 09-04-2003, 08:03 PM   #4
Tom Nugler
Tom Nugler's Avatar
OK. 100 ft\lbs. it is. I don't recall any manufaturer's name cast in the wheels, only a date stamp of 1989 inside the rim. No steel inserts either. Thanks again.
Wheels for 1961 Overlander David Hall Wheels 19 01-29-2004 08:24 AM
Wheel and Hub Balancing plus Aluminum Wheels Cracker Wheels 1 11-05-2003 04:19 PM
Wheels - Nut & Hub covers AccessMaster Airstream Motorhome Forums 2 09-30-2003 03:59 PM
Aluminum wheels smily Wheels 21 03-05-2003 12:32 PM
