Old 11-11-2015, 01:39 PM   #43
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Sorry Brad...just checking!
martin300662 is offline   Reply With Quote
Old 11-11-2015, 01:40 PM   #44
I appreciate the double check! You wouldn't believe how many times I've ordered something only to find out it was the wrong part
Old 11-11-2015, 01:49 PM   #45
Keen amature
1975 20' Argosy 20
Chestfield , Kent
.....I can join that club.....I have a pile of new, but incorrect parts building in my shed!
Old 11-11-2015, 01:51 PM   #46
Maybe between the two of use we could build another Argosy?
Old 11-11-2015, 02:02 PM   #47
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by bkahler View Post
2 sets to go. Put me down for a set.
still 3 sets to go, the new owner of your 310 was the maybe 7
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-11-2015, 07:30 PM   #48
Airstream Driver
1997 30' Excella
Images: 51
8 confirmed, 2 to go
tick tock
1996 Airstream B190
AIR #13
Old 11-11-2015, 11:53 PM   #49
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Peter,
Just caught on to this discussionÖ.
Not sure if these will fit my 370, but the 325 is a sure thing. Count me in for two sets if still possible. If they don't pan out for the 370, I'll make that set available to someone that missed the boat (who generally would be me.)
Ö.And for future reference, the rear drive and tag use a different part that is still in production. Correct???
Thanks for all your efforts!!!
Charly
streamquest is offline   Reply With Quote
Old 11-12-2015, 04:30 AM   #50
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Centramatics
Hi Peter,
as i told you, Tag- and drive is the same!
Was to late to take pictures, allready instaled...!
I will take a pair of the frontbalancers for sure, please keep them till january, i will give you a UPS code to ship!
DO NOT sell your 31 limited to them, untill i have seen it...!
Am terribly busy at the moment, will post pictures soon from Bangles on her road in Germany !!!!
Roquefort is offline   Reply With Quote
Old 11-12-2015, 05:00 AM   #51
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Im currently running the beads on my 310. Tires are about 1.5yo and the ride seems to be as expected from a 35yo bread truck chassis. No unusual vibrations that Im aware of but how would I know if Ive never driven one with the centramatics installed? What would you say is the biggest difference that the centramatics make in the feel of the rig going down the road? Are they installed to "cure" a vibration problem or is it more to enhance the feel of the ride where no perceived "problem" exists? There are so many factors involved in the way the rig feels. I dont want to miss the oportunity here but Im wondering if its money well spent if there is no perceived problem to begin with. Wish I had way to compare the ride with and without.
mayco is offline   Reply With Quote
Old 11-12-2015, 05:50 AM   #52
Airstream Driver
1997 30' Excella
Images: 51
My response is only my personal opinion AND experience:
Tile/wheel vibration is a killer and it costs you money in tire, bearing, wheel and steering components. On top of that, Airstream rivets hate vibrations.
Many of the tire problems on trailers you read about are caused by an unbalanced tire/wheel assembly.
I would compare the driving experience with what you feel when you drive of the tire lot with $2000 worth of brand new michelin tires.
My research let me to believe that any of the beads on the market may cause serious problems to your tire or rim and in the worse case, cause an even greater imbalance due to lumping of the beads. The "Flat" road contact of the tire, negates the roundness they need to run in, causing them to constantly "bump"
If you are happy with the performance, stick (no pun intended) with it.
I will post this video again:
1996 Airstream B190
AIR #13
Old 11-12-2015, 05:55 AM   #53
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by Roquefort View Post
Hi Peter,
Hi Marcus, You already were part of the 10, got you covered.
Since you just had the 4 installed on the drive and tag axle, please share your experience with us.
1996 Airstream B190
AIR #13
Old 11-12-2015, 05:59 AM   #54
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by streamquest View Post
Peter,
Charly
Yes, Charly 400-417 for drive and tag and readily available from Tire Balancers, Tire Balancing, Wheel Balancer and Wheel Balancing from Centramatic
What chassis is the 370 and what tire size, 19.5 I would assume. You may have to call them to find out what you need. I seriously doubt the 400-406 will fit.
Should I just put you down for 1 ?
1996 Airstream B190
AIR #13
Old 11-12-2015, 10:51 PM   #55
1936 20' Clipper
1947 22' Liner
Curtis Wright
Hi Peter,
Just in case you didn't get my PM; Sign me up for one pair for my 325. I spoke with Centramatics, and this part will NOT fit my 370.
Charly
Old 11-13-2015, 06:11 AM   #56
Airstream Driver
1997 30' Excella
Images: 51
Hi Peter,
Charly
Got you down for one, Charly.
9 confirmed and 1 to go.
Never heard of Centramatics Balancing System RangerJay Tires 8 08-20-2010 08:13 PM
Balancing: Centramatics versus Dynabeads wolverine Wheels, Hubs & Bearings 14 04-15-2010 11:25 AM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 10:42 AM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
Wheel assembly balancing - which method?? 83Excella Wheels, Hubs & Bearings 0 03-23-2002 07:53 PM
