Old 11-10-2015, 03:50 PM   #29
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Both the outer wheel on the drive axel and the
Wheel on the tag axel look similar, dished slightly out ward.
Allowing the centramatics to fit in more a flat disc shape.
Tag wheel
tevake is online now   Reply With Quote
Old 11-10-2015, 03:53 PM   #30
And the outer wheel on the drive axel. Also dished slightly out ward.
You can just glimps the centramatics behind this wheel.
Old 11-10-2015, 04:35 PM   #31
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by tevake View Post
The front wheels on my 345 do not have the centramatics , but the wheels do cup inward from the area where they bolt on the hub. So would require the cupping you mentioned for the centramatics to fit up front.
Ok , thanks Richard.
I summarize from your pictures that the rear axle and the tag axle uses the same balancers, which are the 400-417.
These are readily available
Wheel Balancer 400-417 from Centramatic
The front axle (400-406) have been out of production for some time and they are the ones they will make for us if we take 10 pairs.
The steer axle benefits the most from these balancers, IMHO.
so, again to clarify:
The drive axle and the tag axle appear to use the same balancers which is a disk shape and is still available.
The steer axle, which is a cup shape can be produced for us if we purchase 10 pairs.
So far I have 3 confirmed
1996 Airstream B190
1997 30' Excella Wide Body Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-10-2015, 08:59 PM   #32
Airstream Driver
1997 30' Excella
Images: 51
4 confirmed
1996 Airstream B190
AIR #13
Old 11-10-2015, 11:00 PM   #33
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Peter:
One question, how thick are these? The reason I'm asking is that I run steelies all the way around with SS wheel covers. The covers fit over a threaded stud extender that threads onto the last remaining threads of the wheel studs protruding from the wheel nut. If I add too much thickness I won't be able to mount my SS wheel covers.
http://www.phoenixusa.com/images/ins...install-96.pdf
Cheers
Tony
Old 11-11-2015, 05:28 AM   #34
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by Isuzusweet View Post
Peter:
Cheers
Tony
I just measured my 16" set (awaiting installation) and the mounting plate (both front and rear) is 1mm thick.
martin300662 is online now   Reply With Quote
Old 11-11-2015, 07:24 AM   #35
Airstream Driver
1997 30' Excella
Images: 51
Peter:
Cheers
Tony
Tony,
Interesting way to mount wheel covers, I have never seen that concept.
My problem with wheel covers has always been the weights mounted on the rim preventing me from perfectly centering the wheel covers, which adds just another factor of being out of balance.
Thanks for posting the thickness, Martin.
Still only 4 confirmed. Don't miss the last opportunity to get the fronts.
My cost will be passed on to you plus shipping to your place. If I have to order 10 pairs with only half confirmed I will ebay the rest at a much higher price.
1996 Airstream B190
AIR #13
Old 11-11-2015, 08:51 AM   #36
Airstream Driver
1997 30' Excella
Images: 51
5 confirmed maybe 6
1996 Airstream B190
AIR #13
Old 11-11-2015, 12:52 PM   #37
Airstream Driver
1997 30' Excella
Images: 51
6 confirmed maybe 7
Talk to the rep and confirmed order of 10 pairs. Delivery before christmas, cost $189.- plus Tax ( I live in Texas, this is not my business, so i have to pay sales tax) and shipping to your destination. No they don't want to ship them individually, they all have to come to my place.
No money needed until 1 week before delivery. I will contact you and post it here.
1996 Airstream B190
AIR #13
Old 11-11-2015, 12:55 PM   #38
Ya know...I'd hate to be the 10th responder to this deal
Old 11-11-2015, 01:10 PM   #39
Airstream Driver
1997 30' Excella
Images: 51
And check this: The Company Rep wants to deliver them personally to my house, because he wants an Airstream and wants to see my collection. That will save us the freight from the factory to my house
Oh, his residence is somewhere outside of Austin, so i am sure that factors in as well.,,but the first part sounds so much better
OK, guys, 3 sets to go.......
Don't be left behind with shaky front wheels on the way to our big Motorhome Rally on the top of Georgia in the spring
1996 Airstream B190
AIR #13
Old 11-11-2015, 01:56 PM   #40
2 sets to go. Put me down for a set.
Old 11-11-2015, 02:18 PM   #41
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Don't you have the smaller 16" wheels Brad?
They are a different part number and they have steer and drive in stock.
Old 11-11-2015, 02:20 PM   #42
These are for my old 310. The owner would like a set.
Never heard of Centramatics Balancing System RangerJay Tires 8 08-20-2010 09:13 PM
Balancing: Centramatics versus Dynabeads wolverine Wheels, Hubs & Bearings 14 04-15-2010 12:25 PM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 11:42 AM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 08:55 PM
Wheel assembly balancing - which method?? 83Excella Wheels, Hubs & Bearings 0 03-23-2002 08:53 PM
