Old 02-17-2016, 05:54 PM   #141
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by bkahler View Post
That's a nice looking project trailer. Is it one of those projects where you buy low and sell high or is it going to be like my projects where you buy high and sell low?
Stocks is the only thing I buy high and sell low
This trailer will be a keeper for while, needs some work but I love the more recent features, like padded ceiling and no cracking end and front caps.
When are you going to take on a Argosy or Classic project (other than your 310)?
The same day Martin buys his 345
Don't really care for vintage trailers, just too much work and floors are always a big issue.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 02-17-2016, 05:56 PM   #142
Airstream Driver
1997 30' Excella
Images: 51
Well whadda ya know...right in Peter's neck of the woods
7 hours...
1996 Airstream B190
AIR #13
Old 02-17-2016, 10:01 PM   #143
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Peter,
Mine arrived this afternoon!!!! I won't get around to installing them for a while yet, but it will be in conjunction with some new tires once the weather breaks.
Once again. THANKS for all of the energy and determination that it took to make this happen.
Charly
streamquest is offline   Reply With Quote
Old 02-18-2016, 04:52 AM   #144
Originally Posted by PeterH-Airstreamer View Post
7 hours...
For Texas that's just a hop skip and a jump away
Old 02-18-2016, 07:05 AM   #145
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Too long/too many axles. Now if they made a sub-28ft diesel pusher that maybe tempting
According to Fred's website they made one at 27ft but 'ruined' it by putting the bath-room in the back!
martin300662 is offline   Reply With Quote
Old 02-18-2016, 10:11 AM   #146
1982 31' Airstream 310
Henniker , New Hampshire
Mine arrived. I may brave the cold and install them this weekend. I guess now I have to spring for a pair for the rear also. Thanks for your persistence in making this happen.
Keith
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 02-18-2016, 08:21 PM   #147
1986 34.5' Airstream 345
Wake Forest , North Carolina
Centramatics arrived
Peter,
Centramatics were waiting by the door when we got home from a trip.
Thanks again for all your effort and time.
We all appreciate it a lot.
Best to you and your gang.
Dick
ww4nc is offline   Reply With Quote
Old 02-21-2016, 10:09 AM   #148
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just curious to see if anyone is thinking of giving these a paint job first to ward off corrosion.
John figures a good coat of brake caliper paint should do the trick. Poweder coating was deemed too thick.
http://duplicolor.com/product/caliper-paint
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 02-21-2016, 05:44 PM   #149
Cheers
Tony
Tony, I can't answer your question about paint but I'd be leery of powder coating the balancers due to the heat involved in the powder coating process.
Old 02-21-2016, 06:22 PM   #150
Airstream Driver
1997 30' Excella
Images: 51
Cheers
Tony
I think you would void the warranty.
1996 Airstream B190
AIR #13
Old 02-21-2016, 07:37 PM   #151
Dazed and Confused
Isuzusweet's Avatar
Paint it is. I hadn't thought of the heat issue as it's going to get pretty hot where they are going to be anyway.
Cheers
Tony
Old 02-22-2016, 08:10 AM   #152
Malmills's Avatar
1992 35' Airstream 350
Ocala , Florida
Centramatics Delivery
Hi Peter,
I was away and my two packages were pulled into the living room by my mom. I haven't opened them yet but I assume the large contains the two set for the rear. Thanks again for your efforts. I'll be emailing you soon.
Malcolm
Malmills is offline   Reply With Quote
Old 02-24-2016, 06:41 PM   #153
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I installed mine last weekend. I couldn't find anything in the instructions on the rear installation of the dish between the two rims. If you are suppose to install the bead tube towards the outside tire or towards the inside tire. I couldn't see how it would make a difference either way in changing the performance of it balancing, so I called the company and was told they can be installed either way. You would think they would mention that somewhere, or if they did I didn't find it. Maybe if somebody else has the same question this will help.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 02-28-2016, 06:07 AM   #154
Airstream Driver
1997 30' Excella
Images: 51
I still have a set for the P-30 front someone cancelled after I ordered them.
Please PM me if you are interested. This may be your last chance to get a set, since I will not do this again.
1996 Airstream B190
AIR #13
Never heard of Centramatics Balancing System RangerJay Tires 8 08-20-2010 08:13 PM
Balancing: Centramatics versus Dynabeads wolverine Wheels, Hubs & Bearings 14 04-15-2010 11:25 AM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 10:42 AM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
Wheel assembly balancing - which method?? 83Excella Wheels, Hubs & Bearings 0 03-23-2002 07:53 PM
