Old 07-04-2011, 08:20 AM   #1
IPM
1996 clipper gas 34'
Blue Springs , Missouri
what's the correct part number for coach ac compressor?
Mine has the wrong compressor installed, it's a single pulley single belt unit.
Suppose to be twin pulley twin belt.
Works but occasionally belt squeal with one belt.
If I change want to do it once as this is a very tight hard to work on location.
thanks for your time.............
IPM is offline   Reply With Quote
Old 07-04-2011, 08:59 AM   #2
IPM
I wonder if this is it?
The original is an a6 twin grove.......
And this is an a6 twin grove........
http://www.oreillyauto.com/site/c/de...2645&ppt=C0354
Old 07-05-2011, 07:30 AM   #3
IPM
Looks like I have two choices when I install the twin groove ac pump.
Leave the outer grove empty and keep two belts on the water pump or route a larger belt (alternator included) to wrap the outer ac belt for two on the ac. Either way my alignment issue with the current ac compressor will be solved.
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
Front sway bar, Part number for Bushing ? John H. Mechanics Corner - Engines, Transmission & More... 5 06-09-2011 11:27 AM
Part number needed sharptalk Mechanics Corner - Engines, Transmission & More... 5 06-02-2011 01:11 PM
Part Numbers needed for Window and door gaskets Dog Doc Windows & Screens 2 04-24-2011 07:30 PM
Reese Part Number 26002->26102 thecatsandi Hitches, Couplers & Balls 28 04-19-2011 04:15 PM
