Old 05-03-2011, 07:39 AM   #1
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
What size wire for battery hookup?
I have a 91 350LE. I just replaced the chassis battery and the 2 coach batteries with group 27 Lifeline AGM batteries. The original cables will not work with this set up so I need to custom make some cables. What size wire should I use? Steve G
t7389sg is offline   Reply With Quote
Old 05-03-2011, 08:24 AM   #2
t7389sg's Avatar
Laurel , Maryland
added photo
Old 05-03-2011, 08:42 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Larger IS better in battery cables!
I never usually install anything less than 2/0, but for one engine battery 0-AWG should work fine. Depending on the amp draw from your house batteries, you could probably use 0-AWG also, but I prefer more wire than less to eliminate any potential problems. Also, ask for welding cable for your new batteries as they are much more supple and flexible than standard battery cable.
Did you get a GPL-2700T starting battery for the engine and GPL-27T deep cycle for the house units?
Old 05-03-2011, 08:42 AM   #4
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
I use 4 Gauge for my house batteries.. Made my own. I bought the crimper at a local electrical supply house. I bought the end at a welding supply shop.
Michelle TAC MT-0
Sarah, Snowball
Old 05-03-2011, 09:22 AM   #5
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Battery Hook Up
When connecting batteries in parallel try to run the house positive from one battery and the negative from the other battery. This guarantees that both batteries are used. If it is wired as this picture, a dirty connection on the second battery will result in only the first battery doing the heavy work. Just reverse the wire hook up on the negative in the picture and you have a fail proof connection.
Dave
Old 05-03-2011, 11:53 AM   #6
t7389sg's Avatar
Laurel , Maryland
Yes. two 27T & one 2700T My problem stems from the origial starter battery being a side teminal and the new Lfeline batteries have recessed top post so the flag terminals do not fit well.
I think I will just order some welding 2/0 cable/wire and use military terminals. Thanks for your help.
Old 05-04-2011, 09:14 PM   #7
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
..........I think I will just order some welding 2/0 cable/wire and use military terminals. Thanks for your help.
What's a military terminal?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-05-2011, 12:02 AM   #8
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's some examples...
ordance battery terminal - Google Search
It allows you to use 3/8" eye terminals end on your battery cables...
Ray & Pat; Morada, CA
Old 05-05-2011, 05:58 AM   #9
1986 25' Sovereign
Plant City , Florida
When I rewired my trailer I used 4 gauge from each battery in to a block like this. From this I used 1/0 like this. This wire is very flexable and is much finer wire than welding cable. They also carry battery terminals that are rated to use up to 3/0ga.
I was able to purchase all the parts I needed at a local car audio shop for less than $100.
BTW: I have no intrest in the company I listed. It's just what I used.
ck21084 is offline   Reply With Quote
Old 05-05-2011, 07:10 AM   #10
lewster's Avatar
The class K welding cable that I use for most hi power transmission use is basically the same thing, just without the fancy jackets. It is comprised of many very fine conductors wrapped in either black or red thermoplastic elastomer which is extremely flexible and rated to 221*F and is rated for heavy duty use. Much more flexibility than regular battery cables, which I replace on a regular basis.
Old 05-05-2011, 07:34 AM   #11
Maniacal Engineer
barts's Avatar
Menlo Park , California
I used some surplus server grounding cables - very flexible because of the large number of fine strands. For connectors I used bolt-on cable lugs; I like these because they're reusable and can be retightened if needed.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-05-2011, 07:51 AM   #12
t7389sg's Avatar
Laurel , Maryland
I just ordered these
plus 6 feet of 2/0 welding cable black and red. I plan on installing the teminals and then make short jumpers to connect all the batteries. I think the military terminals are better than the marine type because the marine type have wing nuts on top and that may sit too high to close the drawer. Thanks for all the responces to this post. Steve G
One Wire Running Lights---Effects on Grounding tinbender Lights - Interior & Exterior 7 04-18-2011 07:22 AM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
