Old 11-15-2006, 02:18 PM   #43
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I am still on my search for more speed and less RPM. A mechanic was crawling under Chummy and noticed that the passing gear was not connected. He stated that it may never have been connected. Does anyone else have a passing gear?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-15-2006, 03:24 PM   #44
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I think 'passing gear' refers to the way an automatic transmission will downshift under heavy acceleration. This causes the engine to rev higher. Maybe that isn't a good idea with diesel's?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-15-2006, 06:23 PM   #45
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
First off....you folks are NUTS to run a 454 past 3k for extended runs. No wonder folks are popping motors at 80k. Its WAY to fast for a motor of its size. Yeah 4K to pull a short grade getting on the hwy but at 454 is happiest to cruise around 2600-2800 rpm. Past that it starts baking the oil out of it.
My 454 TH 400 suburban has temp gages on the oil and the transmission. with the 3.73 and 235x85x16/s I wont run the thing past 2800rpm even empty for any period of time.
I use to try to run it down the hwy at 75. I kept having issues of getting off the hwy and the engine temps stayed elevated. Even Thought I had a cooling problem. Added a tranny cooler thinking the tranny was raising the coolant temp, didn't fix it. Replaced the radiator....same problem. Put the temp sender in the pan and was SHOCKED at what I found. 2800 RPM or less the engine oil stays at around 250-280. 75 MPH it was up over 300f and hitting 350f on a long run. My truck has a factory Oil cooler and it hits that.
Same deal with the transmission Even with the factory cooler and the AUX cooler Under 2800 RPM it stays under 180. Over 2800 with the elevated engine temps I am hitting 215f quick and thats hot enough to start ruining the seals.
Over drive is what you want. Keep your gearing for the hills and OD for the hwy. Its the best of both worlds.
I am a firm believer that the safest way to drive is with the flow of traffic. If you are running 55 in a 70mph zone you are causing idiots to stack behind you and start taking chances and possibly cause a wreck. It is safer even for the idiots if you can move at the posted speed limit.
I am looking at the Gear vendor or Bowtie OD.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 11-15-2006, 07:36 PM   #46
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Several forums members have had good luck with Gear Vendors overdrive units. My diesel tow vehicle with a 4.10 ratio, and a 3 speed automatic transmission has TWO of them. One on the back of the transmission, the other midway along the drivehaft. Total 40% reduction in RPMs while driving.
If you don't like that, our Isuzu FSR trucks with the same engine as Kent's motor home have Allison transmissions (4 speed). They run 2700 RPM at 65 mph in 4th gear...and 26,000 pounds.
Old 11-15-2006, 08:06 PM   #47
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Kent, it's been some time since we last talked about your rig... is your turbo working now? I remember you stated it didn't kick in much.
59toaster I'm with you. My problem is that the GV route would likely mean I'd have to change my rear end ratio to find the sweat spot. At my present RPM's I'd be down into the lug range at 70 MPH in overdrive. If I could find 500 rpm of overdrive instead of 750 I'd be good to go..... then I'd have to find the $$$. Just agreed to drop $1800 on a new Honda EV6010 today.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-15-2006, 08:10 PM   #48
Well Preserved
1993 21' Sovereign
Why not contact GV and see if they will build you a 10% overdrive, instead of the 20%? You would then be at 2700 RPM @60 mph.
Old 11-15-2006, 11:22 PM   #49
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Transmission
Hi, I would, if I were you, either go with a Gear Vender unit or better yet just leave well enough alone until your three speed gives up then install a four speed overdrive transmission.
Old 11-16-2006, 06:11 AM   #50
GlenCoombe's Avatar
Belleview , Florida
Images: 27
OL63, I'm actually doing better than that already. 55 mph = 2600 =205 engine temp prior to new T-stat.
60 = 2750, 65 = 2900, 70 = 3100 = 210. I'd like to have about 2600-2700 rpm at 70 so as I see it 500 rpm of relief. I think that once you get down into the 2400 range you're out of the power band and risk lugging the engine.
I had no idea you could spec a different final drive.
Anybody need some golf balls?? Just bought a new genset (EV6010) so I'm having to think about all the winter to do's I had planned. I'm still hot on a new floating inlaid wood floor.....
Old 11-16-2006, 08:29 AM   #51
1994 30' Excella
Glen- the turbo is working fine, I just do not need it most of the time.
59 Toaster- The RPM is from a diesel engine not the 454 gasser.
Gear Vendors- I have spoken with them and they do not have a product for my Isuzu engine/ GM transmission.
Chaplain Kent
Old 01-05-2007, 04:10 PM   #52
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I was not aware that CK had a GM transmission. I was talking to the mechanic up the road from me. He has worked in shops that specialize in Isuzu in the past and now is farming and running his own shop. We discussed changing the ratio of the rear end and he says that it's quite simple to do it and he has the tools.
He also mentioned that a friend that he worked with specialized in installing an overdrive gear into the Allison Transmissions. I hadn't heard of that before. He' going to check on that for me.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 01-09-2007, 11:50 AM   #53
dienst1's Avatar
Images: 11
US Gear overdrive
I had the gear set in my US Gear box changed out to the overdrive from the PO's under drive. The difference is amazing. I had it done just before we left Ohio to come back to Southern California for the winter. I was getting 55 mph with a tach reading of 2900 rpm. Now I'm getting 60 mph at 2700 rpm. I have the 6BG1-T Isuzu engine (replaced the 6BD1 when it melted a piston) so it just loafs along at 60 mph. I'm still calculating trip mileage but I expect it will be 14+ mpg. I also had the SCS Frigette electronic cruise control installed at the same time. That really made the trip more enjoyable.
dienst1 is offline   Reply With Quote
Old 01-09-2007, 11:59 AM   #54
The Hawk's Lair
cooperhawk's Avatar
You mentioned a US Gear box. I'm not familier with that. I have the four speed Allison Transmission with the 6bd1 engine with a turbo. I do however have the improved engine with all the upgrades. It seems to have plenty of power.
AKA THE GUNNER
VFW, LEGION, NRA
Old 01-09-2007, 12:14 PM   #55
1994 30' Excella
Originally Posted by cooperhawk
You mentioned a US Gear box. I'm not familiar with that. I have the four speed Allison Transmission with the 6bd1 engine with a turbo. I do however have the improved engine with all the upgrades. It seems to have plenty of power.
I am still searching and the US Gear over under gear box seems to be my only alternative. A four speed tranny would also be nice but mine is the old GM three speed. Chummy goes into the shop next week with a mechanic who is going to establish exactly what is going on now and what I am able to do.
Chaplain Kent
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 02:12 PM
Transmission questions jcanavera On The Road... 6 08-13-2002 09:36 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
Transmission repairs rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 08:51 AM
