Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-18-2004, 06:21 PM   #29
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 215
Originally Posted by argosy20
....one thing I would have replaced with the caliper ....... is the hold-down bolts and the metal slides
Thanks for the heads up....bolt and slide spring were part of the caliper "kits" as were new copper gaskets for the brake line interface. All of the parts were in good shape (except the rotor and pads), and everything that slides received a coating of a special brake parts lube - similar to never-sieze, but made specifically for brake slide/contact areas.
Picture #1 below shows the new master cylinder in place - also purchased a "vacuum kit" to bleed the master cylinder, lines, and calipers - 40 bucks very well spent. Besides the master cylinder, also note the support from the MC bolts to the frame - this has to come off as outlined earlier. One of the new brake hoses is visible at the lower left hand corner.
Picture #2 shows part of the "while your at it" scope of work expansion....ran cold compression numbers while I had every thing apart......not too bad considering 80,000 miles, lugging around 8 tons, and turning over 3,000 rpm at 60 mph.....150 to 170 psi. The plugs (platinum points) had about 8,000 miles on them, and really needed to be replaced. The electrodes were very rounded and had lost a lot of metal.....went back with conventional plugs. The driver sides were very clean - no carbonizing at all, but the curb side (#4 and #6) had a bit of carbon/buildup - but not bad.....when the plugs were changed last the #8 cylinder evidenced by far the worst buildup, but it also had a burnt plug wire....#8 looked pretty good this time.
Hard to believe that it's mid September and the temp index is well over a hundred degrees - the good thing about the MoHo being down right now is that it is still too hot to go camping....a very welcome benefit of the metal roof over the parking area is that a couple of well placed fans on the concrete makes it almost bearable when working under the unit.
Name:	New Master Cylinder.JPG
ID:	8781   Click image for larger version
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 09:28 PM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Rear disc brakes mcneon Mechanics Corner - Engines, Transmission & More... 7 04-26-2004 10:58 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 05:40 PM
