Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 03-05-2008, 09:34 PM   #1
Fairbanks , Alaska
We got our 1st Airstream 2 days ago!!
Hello all, we are now the very proud owners of a 1989 345 LE.
We are on our way back to CT, and have been having lots of morning/starting probs...(so if we could get someone's input by tomorrow morning--that would be great!!)
Engine starts fine (454 w/ 80,000 miles or so...) and we let it warm up for 5 - 10 minutes. Then, we hit the road...and as soon as I think we're ok...the engine seems to choke on itself...and then dies.... I can restart, if not in gear, rev it up, then I put it in Drive...go up to 15-20 MPH's...and duh.....dies on me again...But, here is the catch...after an hour (this morning) driving with the hazard lights on etc.....the problem seemed gone...and we drove 200 beautifull miles... What am I doing wrong? I was told by seller, that we needed to have the engine at op. temps.... Please help...(it sounds kind of weird to have to let the engine warm up for an hour?) -- It is very cold here in Northern Ohio....
Hope someone here can help us....Love our airstream and this forum!!
gypsychris is offline   Reply With Quote
Old 03-05-2008, 10:31 PM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
Welcome in and CONGRATS!!!!!!
You got a sweet Moho.
Here's what to do to get help from someone that knows.
Post a new thread with a title like. "Need help with my 345LE Engine!"
That way the Moho owners and the engine guru's will see it and help out.
Sounds to me like your automatic choke isn't but Im no engine whiz. There's also a Moho forum here and you may find your answr there and with the search function.
Good luck.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 03-05-2008, 10:47 PM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
north ohio?
can we help we are west of cleveland
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 03-05-2008, 10:58 PM   #4
loudruff's Avatar
1989 29' Excella
some things to check on
Just some quick thoughts:
If you started out with a tank full of old gas, or it had some condensation in the fuel and moisture in the lines...old filters etc. you may have solved the problem just by driving it and adding fresh fuel.
Maybe a couple of cans of fuel conditioner couldn't hurt it. If it is actually an operating temperature problem partially blocking the radiator with a piece of cardboard is an old trucker's trick...in the cold weather. If you try this keep an eye on your temperature gauge and don't let it overheat.
Pull and change fuel filters.
If someone comes up with better ideas and you need a spot for the night we have lots of tools and a place to work. We have full hookups here. We are just off the major highways and there are lots of full service garages close by, as well as a big Chevy dealer.
You can PM us if you need directions or further help, or to get our phone number.
Larry and Lou
Air #2695
TAC- OH 2
Old 03-05-2008, 11:25 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I would also bet on a dirty fuel filter.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 03-06-2008, 04:38 AM   #6
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Chris...welcome to the forum and congrats on your purchase. Sorry to hear you are having issues. Is the MH gas or diesel?
If gas, the problem could be the carbeurator or choke; if diesel, the problem could be with glowplugs.
Perhaps a moderator could change the title of this thread and move it into the MoHo forum. Then the real experts could chime in.
Good luck and let us know how you make out.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 03-06-2008, 05:32 AM   #7
Fairbanks , Alaska
Wow...thanks so much for all the replies. I am going to start another thread in the MOHO forum....I found a new fuel filter in one of the cabinets... but am not sure where to replace it? are there two fuel filters? It is a Gas MH. the 454 Engine. Thxs!
Old 03-06-2008, 05:40 AM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
Fuel Pump -
There is an electric fuel pump just forward of the 80 gallon fuel tank - a pesky critter to say the least.
Purchase a fuel pressure gauge and a good electric meter - you WILL need both -
Do a search on "345 fuel pump" here on the Forums.
Luck
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-06-2008, 05:43 AM   #9
87MH's Avatar
1978 31' Sovereign
Images: 292
Actually, there are probably three filters - just before the rear electric fuel pump, just forward of the electric step, and around (or in) the carb or fuel injection system.
Dennis
WBCCI # 1113
AirForums #1737
Old 03-06-2008, 05:50 AM   #10
Fairbanks , Alaska
can someone please explain a bit why it would work fine after restart etc..and after it warms up...but not in the cold AM..does that all have to do with fuel supply/pumps/filters? Sounds strange..and am just trying to understand how she works :-) THANKS!!
Old 03-06-2008, 06:10 AM   #11
87MH's Avatar
1978 31' Sovereign
Images: 292
Grasshopper -
The Beast Doth Protest if Worked Unduly....
I have owned one of these eight ton monsters since January of 2003 - I daresay I have been into each and every system at least once.
I have come to believe that, just like a woman, there is NO understanding them. Take each mechanical malfunction as a camping adventure - make sure you get a good towing insurance package (Good Sam's is who I use), don't sweat the small stuff - if you don't get there today - you'll get there eventually.
As far as "understanding" how the mechanicals work, remember that the entire system was somewhat marginal twenty years ago when the units were manufactured. Leaking connections and old hoses will huant both the 454 and the Onan - the fuel systems will suck in air and loose prime at the most unbelievable places.....to say the least, they are maintenance hogs.
On the upside, they are probably the finest and most recognizable gasoline MoHo ever manufactured. Good luck in your endeavors - have patience in your troubleshooting - you will often find multiple "reasons" for any particular system not working. The good news is that each of the systems are relatively easy to get to, each can usually be handled by only one person (very seldom will you find you need two people to work on it), and engine and running gear parts are still abundant.
Dennis
WBCCI # 1113
AirForums #1737
Old 03-10-2008, 05:56 AM   #12
Fairbanks , Alaska
Ok...so we made it home !! long story short...we had all fuel filters checked...found three, and now I know where these are... :-) It turned out that the rear fuel pump, by the tank, was defective, and the mechanic replaced it. The drive to CT was great, and we are now cleaning/re-doing the interior... Thanks to everyone for your support!!
Old 03-10-2008, 09:04 AM   #13
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Pictures, we need pictures. Take before and after, so we can see how talented you are.
juel is offline   Reply With Quote
Old 03-10-2008, 09:09 AM   #14
soldiermedic's Avatar
Florissant , USA
Welcome to the forums. We're glad to have you.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-10-2008, 09:13 AM   #15
Midamrail's Avatar
1975 Argosy 26
Villa Ridge , Missouri
Here's a second vote for pictures - I love the paint scheme on the 1989 MHs.
Both Alex, my Argosy, and I are kids from Versailles, Ohio!
Midamrail is offline   Reply With Quote
Old 03-10-2008, 09:55 AM   #16
Fairbanks , Alaska
Pictures That made us Go and Get it!
Here are pictures that the seller sent us via email, before we decided to go look at it...am repainting the end cap in the bedroom, re-covering the headboard and underbed door (they were pink and nasty...) hopefully will be done sometime in the next 3-4 hours...have been working some 20 hrs on this room alone--- I am afraid of paint leaks on the carpeted walls....we shall see !!! Here are the pics... Oh...and does anyone know of leather covers we could put on the captain chairs and the swivel ones? The fabric inlets on these is torn up....
ID:	55919   Click image for larger version
ID:	55921   Click image for larger version
ID:	55923   Click image for larger version
ID:	55926   Click image for larger version
Old 03-10-2008, 12:37 PM   #17
Fairbanks , Alaska
btw, the pictures lie a bit....its much more irty than it appears...
Old 03-10-2008, 03:56 PM   #18
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Gypsy: Nice looking rig. It's gotta be fun for you.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 03-10-2008, 04:45 PM   #19
Robfike's Avatar
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia , Alabama
Welcome to the forum. If you are like us, the more stuff you do to your coach, the more you will love it!
Rob
Robfike is offline   Reply With Quote
Old 03-11-2008, 04:57 AM   #20
Fairbanks , Alaska
LOL....we are in love already!!!
the 12 days of christmas....airstream style 2airishuman Off Topic Forum 87 12-24-2010 12:59 PM
Just bought our 1st Airstream greg_n_ Off Topic Forum 23 07-22-2008 02:23 AM
My 1st Airstream gmp5 1966-68 Caravel 3 10-15-2006 06:04 AM
Where Were You Six Years Ago! AirstreamGypsy Member Introductions 6 02-04-2006 09:07 AM
Got my 1st Airstream hookedonclassic Our Community 12 09-25-2005 06:22 PM
