Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-12-2007, 06:34 AM   #1
Normin storm
Normin storm's Avatar
Profile:  1982 31' Excella
Street , Somerst
Question water in sump
Hi I have airstream with 454 engine after the fan belt snapped and having problems starting I finally started it and the engine fired and loaded all the water from radiater into engine it was not mixed with oil it was seperate is it teminal or is there a way that oil can get into the engine i.e. busted pipe if it was head gasket surely oil would have emousified am new to these engines
Normin storm is offline   Reply With Quote
Old 11-12-2007, 07:50 AM   #2
Wayne&Sam
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
I don't know about the 454, but I had a sump take on water from a leaking water pump housing gasket on a Land Rover. If you were lucky enough to shut it down right away maybe you're ok. Maybe.
Old 11-12-2007, 08:56 AM   #3
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Thumbs up Wayne,
If you shut down right away you did not overheat your engine . If you did not you may have warped the heads or blew out the head gasket.
The second problem coud be a craked head from the heat.
The third problem could be a bad casket on the water pump.
The solution is flush out your motor, change you oil filter, and take to the shop where they can test your radiator to see if it has carbon monoxite in the water.
Good luck
Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 03:18 PM
Shower sump pump? malconium Sinks, Showers & Toilets 17 05-25-2007 10:22 PM
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 1 05-04-2007 11:47 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
