Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-16-2006, 11:36 AM   #1
Geophilist
Profile:  Norfolk , Virginia
Wandering tachometer
I am having a problem with the Tach on my 82 Excella gasser. At idle the reading is completly steady. However, at speed it wanders about 500 to 1k rpm. I have noticed that if I push in the cigar lighter, it will jump even more.
I have cleaned the HEI connections and have crimped in the connector a tad to make it fit a bit tighter, but to no avail.
Any thoughts?
Steve
Geophilist is offline   Reply With Quote
Old 08-16-2006, 11:54 AM   #2
Robfike
Robfike's Avatar
Profile:  Speedway , Indiana
You may want to check your grounds behind the dash. I have fixed a number of odd readings of different instruments just by making the grounds better.
My latest one was when I opperated my switch for the door dead bolt, I noticed the light in the vacuum guage would come on slightly. I found that the switch uses the ground for the vacuum guage illumination, and it was loose.
Good luck, Rob
Robfike is offline   Reply With Quote
Old 08-17-2006, 03:20 PM   #3
Geophilist
Rob,
Thanks for the tip. You indicate that there are a number of grounds behind the dash. Any idea how many? I have cranked down on one, but don't remember more than one. Than again, I don't remember what I had for lunch either.
I will go look for more.
Thanks again,
Steve
Old 10-11-2006, 08:48 PM   #4
silver buffalo
silver buffalo's Avatar
Profile:  Floyds Knobs , Indiana
Steve,
Have you cured your wandering tach problem? My 310 does exactly the same thing. The tach is very steady and smooth all the way up to 3200 - 3300 RPM for the first 4 or 5 minutes the engine runs, after it is good and warmed up, anything over 2400 RPM and I get about a 500 RPM bounce, always down. I have had the gauge panel out and tried to check all the grounds but it is pretty intimidating back there (a mess of wires that all seem to end up running to each other at some point). This bounce just developed at the end of last season.
Rick Hill
83' 310
AIR # 2905
silver buffalo is offline   Reply With Quote
Old 10-12-2006, 11:58 AM   #5
Geophilist
Rick,
I am yet to solve the mystery, but if I do, I will share.
I have gone over the grounds and everything looks good there. The problem with finding this is that I have to be going highway speeds to find it. Not recommended if you work alone.
I know whatyou mean about the spaghetti behind the instrument panel. A number of folks have changed out their gauges and have had to deal with the mess. It seems like the only thing that the wiring diagram and the real wiring have in common is coincedense!!
Good luck in finding your problem. Let me know if you do, please.
Steve
Old 10-17-2006, 09:10 PM   #6
Dog Trainer
Profile:  richmond , Michigan
Try running a ground from the ground lug on the tach directly to the battery ground. If this solves your problen then you know to look deeper into the dash wiring. If not then you have eliminated that potential problem
1993 Legacy35 DP MH
Shadow & Duchess Furry Children
(Golden Retriever Therapy Dogs)
1997 Saturn Toad
Dog Trainer is offline   Reply With Quote
Old 10-17-2006, 11:12 PM   #7
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
This may be from left field and have nothing to do with your vehicle. But....
When I worked for GM way back when, I seem to recall that they used a tach filter to smooth it out. Have you checked with the manufacturer or dealer? Just a thought.
Fyrzowt is offline   Reply With Quote
Old 10-20-2006, 10:36 AM   #8
Geophilist
Good advice, Dog Trainer. Next time I get on the road I will give it a shot.
As to the tach filter, I have no clue. I have looked at the wiring diagram, and do not see that one was installed. What do they look like and where might one be? I guess if there is one it could have failed. How would I be able to replace one?
Steve
Old 10-20-2006, 10:54 AM   #9
Fyrzowt
Fyrzowt's Avatar
Images: 8
Steve
Steve, I'm sorry, it's been too long and the cobwebs of the mind are too thick. A call to the dealer should let you know if that's even a possibility. I worked on Cadillac and Oldsmobile, the tach input came off the distributor as I recall. There were two wires with push-in plastic connectors to the distributor cap where the coil is. One was the 12v power lead, the other the tach lead.
I do know the filters were used, but I don't recall if it was original or a problem fix part. FWIW.
Dave
Old 10-23-2006, 06:55 PM   #10
silver buffalo
Steve,
We just returned from the rally in Ga.. Before we left I replaced the coil, cap, rotor and ?? (the flat thing in the bottom of the distributor with 4 male spade terminals on it), no more wondering. She was rock steady.
Rick Hill
83' 310
AIR # 2905
Old 10-23-2006, 07:53 PM   #11
ralley
Profile:  Prince Frederick , Maryland
Originally Posted by silver buffalo
Steve,
ignition module. Buy another and put it it your tool box.
ralley is offline   Reply With Quote
Old 10-24-2006, 11:00 AM   #12
Geophilist
Rick, Rally,
Had not thought of the "flat thing in the distributor", I will buy a pair and try it out. You know where the second one goes; along with an alternator and starter motor. Thanks.
Dave, I really know about the cobwebs. I hear that forgetfulness is the second sign of getting old. I forgot the first. I will call around about the filter. Thanks for the help and good thoughts.
Steve
Old 10-24-2006, 11:29 AM   #13
Geophilist
Ok,
Old 10-24-2006, 11:38 AM   #14
Geophilist
Dave,
Ok, I have called around to half of the Chevy dealers, RV dealers, and an electronics store in Tidewater, and they tell me that the filter is no longer available. One said, "oh, yeah, back when they made cars with points and carbs they used to have those filters." Now I am really feeling old. One counterman described it as looking like a condenser only with two wires and was mounted somewhere on the maifold. Guess I will go on a snipe hunt.
Thanks again
Steve
Dallas, TX ArtStream Off Topic Forum 4 05-26-2006 10:50 PM
Tachometer failure!! ralley Mechanics Corner - Engines, Transmission & More... 5 02-24-2006 07:04 PM
While Wandering... wahoonc For Sale & Wanted 0 06-26-2004 09:15 PM
Where is the tachometer connection? AccessMaster Mechanics Corner - Engines, Transmission & More... 13 06-29-2003 06:26 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 05:47 AM
