Old 06-28-2004, 11:32 AM   #1
Voltage Issue
My 1981 MH with the Isuzu was showing the volts in the red range on the voltmeter. Replaced the voltage reulator and the power output still shows way up in the red range. Any suggestions?
Rayk is offline   Reply With Quote
Old 06-28-2004, 11:53 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Which Voltage?
If you are referring to the chassis alternator, check each cell in each of the batteries connected to the alternator. Then give each battery a "drain" check - put a known load on the batteries and check the voltage drops. A battery service center should be able to do this.
Check the actual voltage in the charging circuit at varoius points within the circuit. These points include alternator output, isolator in, isolator out, (the isolator "splits" the charge circuit to the house battery and the chassis battery), and the voltage at each battery (check both the terminal clamps and the terminal posts) while the engine is running.
If you are convinced the new voltage regulator is good, sounds like a wiring or battery problem to me.
Welcome to the Forums.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 07-06-2004, 10:38 AM   #3
Problem corrected
I got back into the problem. The batteries where checked and found to be good. Put batteries back in service and broke out the voltage testor. The readings at the batteries and at the isolatotors were all in the 14.5 volt range. ( The volt gage showed over 18 volts). I then hooked the voltage tester to the back of the voltage gage and it also ran in the 14.5 volt range. The problem was a malfunctioning voltage gage. Purchased new gage and installed it. Everything is working fine.
Trailor Life (July 2004 issue) AirHog Commercial Listings 1 07-02-2004 10:17 PM
Univolt Voltage Joe62984 Electrical - Systems, Generators, Batteries & Solar 5 03-01-2004 01:58 PM
Voltage Regulator Rayk Airstream Motorhome Forums 2 09-16-2003 06:36 PM
Alternator/ Voltage reg LKappenman Mechanics Corner - Engines, Transmission & More... 7 10-24-2002 10:24 AM
