Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-27-2010, 01:41 PM   #1
Volt Meter dropped to 10v Intermittantly
A couple of times on my trip last week I saw the Volt meter on the dash drop to 10v.
Most of the time it was 12.5 to 14v, and I thought it was maybe just the gauge, but one time when it was getting dark it did it and the headlamps dimmed noticably.
Looking thru the paperwork I see a new Altenator and voltage regulator some time ago...
A short, bad connection or something going bad?
Ideas?
Old 04-27-2010, 02:47 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The first thing I would look at is the battery terminals. Remove them. clean them and retighten them.
If the motor in your truck is a GM, and while the battery terminals are off, remove, clean and retighten the main cable on the starter. GM uses that terminal as the main distribution point and over time an repeated temperature changes the terminal begins to open, often resulting in a no start condition but you may catch it before that happens.
Your problem is an intermittent high resistance most likely caused but a loose connection in the high current circuit coming off the battery.
2004 Excursion 4x4
Old 04-27-2010, 03:13 PM   #3
Its a BBC, so i will get under there and check. It started and ran perfectly...
Old 04-27-2010, 03:28 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Sounds like an alternator to me.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-27-2010, 04:06 PM   #5
345bill's Avatar
Las Vegas , Nevada
Another spot to check is where your neg battery cable actually connects to the frame. Mine loosened up there once and caused intermittent no start / volt meter fluctuation.
345bill is offline   Reply With Quote
Old 05-07-2010, 02:25 PM   #6
I found a bathroom fan that was on, seized, and was eventually blowing the fuses on the main fuseboard.. maybe that was the problem, I will see next time I drive it.
Old 05-08-2010, 05:49 AM   #7
Ideas?
Its probably your ignition switch and/or headlight switch. Several of us have or have had the same problem. On mine the more lights I turn out (parking lights, headlights, running light) the lower the voltage dropped. Also the power feed to the main fuse block is inadequate which also causes problems. There are several threads on these subjects. I don't have time at the moment to go into more detail but if you do a search on my bkahler or guy99 you should come up with something.
Good luck!
1975 24' Argosy Motor Home
12 volt
Look who dropped in for the holidays... overlander63 Off Topic Forum 16 04-20-2009 05:35 PM
Dropped off in the driveway... GEARHED Member Introductions 6 08-24-2007 03:18 PM
Volt - amp meter? Kistler Electrical - Systems, Generators, Batteries & Solar 9 06-19-2007 04:11 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Logged in....dropped off pyanke Forum Admin, News and Member Account Info 9 03-03-2004 08:54 AM
