Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 07-09-2016, 03:47 PM   #1
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Vacuum hose replacement TBI 89-92?
Hi chaps,
Can anyone point me in the direction of the best place to source those small vacumn lines (shown) which feed in and out of the Throttle Body/EGR valve etc?
They should be consistent for the 89-92 250/290/200/350 series, but I can't seem to easily find them. I am assuming they are all shaped hoses i.e. pre-made, not just off the shelf hose.
thanks!!
Nick
ID:	266322   Click image for larger version
Boom Sounds is offline   Reply With Quote
Old 07-09-2016, 05:57 PM   #2
Nick, due to the age of the motorhome I doubt those plastic tubes are available anymore.
You might considering buying some hard plastic tubing and using a heat gun to shape them to fit. Sorry but that's the only suggestion I can come up with!
1975 24' Argosy Motor Home
Old 07-10-2016, 04:30 AM   #3
Okies, thanks Brad
Old 07-10-2016, 06:23 AM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Brad is correct, The plastic tubing is still available from Napa and other parts stores, however you would need a heat gun to make the proper bends and you would still need regular vacuum line for the termination points, If you really want to stay original you could possibly get the OE part numbers and Goggle them, on second thought I would try places like GM parts direct or Rock Auto. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 07-10-2016, 07:42 AM   #5
Thanks guys, I'll continue hunting around for the OEM parts numbers. They must be in one of the Chevy repair, service or parts manuals, but I am yet to find them! I shall post the relevant details should I manage to find them.
454 TBI, yes/no good/bad idea? bkahler Mechanics Corner - Engines, Transmission & More... 162 06-20-2016 08:00 AM
454 TBI conversion kit bkahler Mechanics Corner - Engines, Transmission & More... 44 02-22-2016 12:57 PM
TBI tuning SebasSF Mechanics Corner - Engines, Transmission & More... 5 01-21-2014 09:54 PM
Vacuum hose help on my motorhome. Myrtle lynn General Motorhome Topics 7 03-30-2011 06:44 PM
Bypass TBI water jacket???? Taxman General Motorhome Topics 8 06-15-2007 03:20 PM
