Old 03-13-2006, 07:24 PM   #85
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Originally Posted by PeterH-79MH
All of this points to the very first wire from the starter solenoid to a junction block to be bad due to a blown fusible link.
Or a bad/burned wire, or ground that became bad recently. I'm asking from ignorance here, but all of this started when CK replaced his dashboard, right? (I'm sincerely asking) Any time you disconnect that many wires at one time, there's a bunch of stuff that can go wrong. The point is that whenever you disconnect that much stuff, there's a lot of opportunity to break or damage a wire that maybe you can't even see. Like you 79, I think the base probelm will be traced to a wire someplace. A wire that is grounding that shouldn't, a hot wire that has lost it's connection, etc. This is why I hate to work on wiring issues between the firewall and the engine. The stuff aft of the front seats is easy compared to the engine compartment.
www.nesa.org
Air No. 6427
Old 03-13-2006, 08:22 PM   #86
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Yeah
I knew you could do it given time
Garry
Old 03-14-2006, 09:52 AM   #87
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
[quote=PeterH-79MH]I would like to make a prediction:
Once the new Isolator is in place, hooked up just like it was before, Chummy will not have power to the main fuse block.
The current Isolator is probably not even defective.
I hate to say it but Peter was correct. I had the Isolator tested and it was OK. Taking Peter's diagram all of those wires are perfect. No soft or spongy areas, no noticeable burn marks, nothing loose and no fuse-able links! I have been on the internet for the past several hours learning about fuse-able links and even took an on-line course about auto electronics to learn how to spot a fuse-able link. I tell you there are no fuse-able links at this location or any other location that I or anyone else who has looked at this problem has been able to find. If you read the owner's manual from AS it has many entries that what they are describing does not pertain to the diesel. I am convinced that what they did with the few diesels they built was to cobble them together with whatever was available and if it was not available in the plant they went to the local farm supply store and purchased what they needed.
Chummy may become a planter/ lawn ornament after all.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 03-14-2006, 10:20 AM   #88
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Good to have you and Chummy back on the Roads!!! That must have been frustrating days searching for the problem...
TG we have a trailer!!
mmmhhh, ok, well...
...at the moment all wires are out and the new electric system has to be installed in the next weeks or month... Hopefully our trailer lights and all the rest will run after that...
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 03-14-2006, 10:21 AM   #89
Got gandkids?
Humm......
Rev, we're not giving up on Chummy yet! I'm not familiar with isolators, or even with MOHO's for that matter, but that doesn't stop me from having an opinion! Let me noodle this out for a minute.....
1) We know that when you take the isolator out of the circuit, everything associated with the dash works as it supposed to, at least I think that's what I'm reading here. Is that correct?
2) You had the isolator tested and it tests good, but still doesn't seem to work when installed the vehicle, right?
3) Is it possible that the isolator tests good, but could be just a bit out, or not quit working normally?
4) Is it possible that soemthing on the "backside" of the isolator is interferring with its normal operation? As I understand it, the isolator's function is to "divide" the 12v power into 2 circuits, essentially. One circuit serves the drive/engine functions, the other circuit serves the "camper" portion of the MOHO. Is it possible to disconnect the "camper" from the "engine" functions at the isolator and see if that works? I'm not sure that is a safe idea (wouldn't want to break something else in the process), but something to possibly look at.
5) Did I mention that I hate electrical problems?
Keep the faith, somebody will figure it out.
www.nesa.org
Air No. 6427
Old 03-14-2006, 10:23 AM   #90
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
It is driveable as it, just the house battery will not charge.So maybe its time to drive it over to an automotive electric specialty guy who can check those circuits.
PeterH know his stuff, no doubt. But hisplace is too ling to drive for you.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-14-2006, 11:39 AM   #91
1994 30' Excella
Alan you are right on the mark. I just got off the phone with a guy who said he would take Chummy as long as I had not filled him full of dirt yet. The place that tested the isolator this morning recomended this guy. Chummy is drivable if I jump the isolator. I have kept the coach batteries disconnected throughout this entire process, no sense in involving a total different circuit here.
I am going to start putting things back together so I can drive the few blocks to his shop.
Chaplain Kent
Old 03-20-2006, 12:59 PM   #92
1994 30' Excella
This Time For Certain
This time is for certain. Chummy is fixed!! Thank-you Peter for the phone call and talking me through some of the wires. However, when all was said and done those wires were fine. But Peter said something which stuck with me all night and this morning as I tracked down the two red wires from the alternator which turned into the green wire which terminated at the "Battery Condition Gauge." He said sometimes they will run the power through a gauge. This is exactly what was happening. All wires were fine. All fuse-able links checked out, thanks again Peter for teaching me how to check Ohms. There was power to the battery condition gauge, no power to the ignition unless we jumped past the battery isolator, or the battery relay off the alternator. The only thing this was doing after I pulled all the wires was by-passing the battery condition gauge. I feel like leaving off here and running a contest, a puzzler to see if anyone can figure out what the problem was. Hint, the gauge was not bad. OK, you guys have been too nice. I had the wires switched from the AMP gauge to the Battery Condition Gauge. When I connected the wires up to the AMP gauge that were on the battery Condition gauge and vice versus, everything worked. Over two weeks of testing wires and pulling fuses and cleaning contacts and sweating and yes even doing a little swearing for something as simple as that. I kept telling myself that logically there must have been something I did which caused this to happen and there was.
So now I begin the task of taping and re-hanging and re-directing miles of wires so it looks like it did before I began.
Thanks again for everyone who had input here. Special to Norbert and Dave and Peter.
Chaplain Kent
Old 03-20-2006, 01:07 PM   #93
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Fantastic!! It's always something overlooked that will just wear you out. I'm certain the weight lifting was very nice indeed. Now you're an expert in the wiring department. Not many of us have had the courage to go as deep into that maze behind the dash to learn what you did. Congratulations on finding the problem.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 03-20-2006, 01:15 PM   #94
_
well congrats chaplain kent........
we've all been waiting for an update, and some good news.......
so you had your wires crossed?
i'm so happy you're up and running again.....
you might want to add this this quote to the 'famous last words' thread......
Originally Posted by Chaplain Kent
This time is for certain. Chummy is fixed!! .
cheers
2air'
Old 03-20-2006, 02:52 PM   #95
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
YES! Another sucess!!!
We've had you in our thoughts thru this all!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-20-2006, 05:06 PM   #96
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Chaplain Kent!
Hooray! I'm happy for you. Isn't it amazing how you can go through things 20 times and then suddenly you see it?
Now repeat after me in your best Joan Crawford "Mommy Dearest" voice, "NO more Aluminum Planters"!
Tin Lizzie
Foiled Again is online now   Reply With Quote
Old 03-20-2006, 07:40 PM   #97
1991 35' Airstream 350
Windsor , North Carolina
Ok--I'M THINKING HALLELUJAH CHORUS IN THE BACKGROUND, WHISTLE WHILE YOU WORK AS A SUBTEXT, AND "THERE WAS BLUE VELVET LANGUAGE...... well, nevermind. It was bound to happen sooner or later.
I think we have all learned a great deal. Thank you, Chaplain!!
R
ralley is offline   Reply With Quote
Old 03-21-2006, 05:45 AM   #98
1994 30' Excella
Chunmmy at His Lowest
I just needed to post this picture of Chummy at his very lowest point. Myself at this juncture looked a little worse.
Name:	chummy at its lowest.jpg
Chaplain Kent
