Old 08-05-2018, 10:44 AM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Turbo diesel fuel filters
A question for you Classic Motorhome Turbo Diesel folks. What filter element are you using in the lower filter, the one in the Racor? What brand and how many micron? If you have the number that would be great! Ive been using Napa Gold
3208. Just wondering what others are using to give me more selection and vendors. Thank you fellas!
Mike
mayco is offline   Reply With Quote
Old 08-05-2018, 10:50 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Don't have a number but 2 microns should be your final filter. I would just use a Racor element.
Just make sure if there is a water drain that you get it sealed tight. I drained water a week before a trip and spent 3days in a shop till they saw air bubbles in the Racor.
2004 Excursion 4x4
Old 08-05-2018, 09:19 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Mike the Racor filter comes in 2, 10, and 30 micron. The real question is how much crap in your fuel tank and often do you want to change filters? As Howie said your last filter, the little guy on the top right front of your engine, wants to be 2 micron. If you don't mind changing that one, run a 30 micron. If you don't want to change the Isuzu filter, run a 2 micron Racor and you can change that one instead.
I added a large 30 micron filter, Wix 33118, ahead of the Racor. It is nearly 8" tall x 3 3/4" in dia. It picks up the heavy crap and holds a bunch of it. Then comes the Racor in which I run a 10 micron, Racor 2010TM, Wix 33795, or Baldwin PF598-10. Last is the little Isuzu which lasts a long time because it doesn't see anything bigger than 10 micron. It's just so much easier to change the big spin-on and the Racor.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 08-07-2018, 10:22 AM   #4
mayco's Avatar
Ok fellas, thank you. I'm using a 10 micron now in the Racor, I need to look up the specs on the one I'm using up top. Ill make sure it's a 2 micron.
Old 08-07-2018, 03:32 PM   #5
mayco's Avatar
Further research reveals that the OEM filter, the one on the motor itself, IS a 10 micron filter and not a 2 micron. OEM Isuzu part # 9885111911. Aaaaaaaand now I can't find the link with the spec on that filter but it is 10 micron.
Old 08-07-2018, 04:06 PM   #6
In looking it up it is listed at 10 micron. I would guess pumps and injectors weren't quite as tight 35 years ago. With diesel cleaner is always gooder. With my set up it is much easier to change the Racor and the spin on pre filter then to play with the Isuzu. I can't even remember the last time I changed the Isuzu and being lazy that works for me.
I did find a couple 2 micron Racor filters in the spares from the PO. They would last about 1000 miles before plugging up enough to cause power loss. That is when I added the pre filter.
Cheers, Dan
Old 08-07-2018, 04:14 PM   #7
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
20 micron for pre filter and 10 micron, engine filter; 2 micron, and as Dan stated, it'll just plug up fast.
I don't have a Racor prefilter, so I can't help you lot.......for some reason, my pre filter is a whole lot bigger......the filter is almost 8" long.
Cheers
Sidekick Tony
PS The best prevention is to diesel up at a well used station.
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-07-2018, 05:57 PM   #8
mayco's Avatar
Ok now one more question. how often, either time or mileage, do you change the prefilter (Racor)? One forum member posted that he changed the prefilter with every oil change. Seems a bit overkill but what do you think is a reasonable interval?
Old 08-07-2018, 06:31 PM   #9
Dazed and Confused
Isuzusweet's Avatar
The more prudent question for me would be......when does he do his oil changes?cause I'll go a few years before changing fuel filters.
I maybe wrong, but 25,000 miles if you're getting good quality diesel wouldn't be out of line.
Cheers
Sidekick Tony
Old 08-08-2018, 05:02 AM   #10
mayco's Avatar
He was changing oil every 3500 miles. Ive been changing mine once a year but this past year the mileage snuck up on me and didn't realize it. Changed oil last week and we had 7000 miles since last August.
Old 08-11-2018, 10:47 AM   #11
1971 27' Overlander
Kansas City , Kansas
Filters are cheap. When I worked at an Isuzu Dealership we changed filters at 3500 miles. It was in Oregon and the diesel in the area (Eugene) was terrible. I previously worked at a Fuso dealership. We changed fuel filters at 7000 miles.
The problem with running a high micron filter and not changing regulary is when you're driving around with half clogged filters, you're putting a bunch of vaccume (or pressure depending on vehicle), on the diesel lift pump, causing premature faliure.
If you happen to own a newer common rail diesel, this can be very expensive. Even on an older diesel, the cost of a filter is a much better choice.
Shermy1987 is offline   Reply With Quote
K & N Air Filters on Diesel Engines dlombardozzi Tow Vehicles 45 02-09-2019 09:35 PM
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
Fuel Filters CarlGeo Mechanics Corner - Engines, Transmission & More... 1 05-24-2008 07:52 PM
Land Yacht Fuel filters. Taxman Land Yacht/Legacy Motorhomes 0 08-23-2007 04:53 PM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
