Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-20-2007, 08:42 PM   #1
jagcb750
jagcb750's Avatar
Profile:  Barbourville , Kentucky
tune up for MH
I am getting ready to do a tune up on Nancy I was going to change out the:
1 oil and oil filter
2 spark plug and plug wires
3 air filter
4 distributor cap and rotary button
5 coils (this thing does have coils on it doesn't it? 454 gas engine)
6 transmission filter and gasket (pan is leaking a little)
What else should I look into? I am going to look around for a maintenance schedule pamphlet. Seems like I saw one with my paperwork. I read on a post in this forum somewhere about fuel filters, so I am going to try to read up on this to see how many and where they are. Are there any smog control type filters or egr valves or anything? Anyways any advice on this would be appreciated as always. Thanks
JaG
My "new" 1986 345: "Ol Nancy"
jagcb750 is offline   Reply With Quote
Old 09-21-2007, 04:18 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Reference item 5, your motor does have a coil, and it is probably mounted on top of the distributor cap. Coils are not usually considered maintenance items though.
Item 6 - A new filter won't hurt anything, but you may want to let a reputable transmission shop replace it. A skilled technician can tell you a lot about the transmission simply by looking at what has settled in the pan.
Inside the carb air filter housing, on the left-hand side, is a small, sponge-type filter. In a new engine, air is drawn through this filter into the passenger-side rocker arm cover. In an old or ailing engine, engine fumes & oil are blown into the filter (not good). Clean the filter and make note of which category your motor falls in.
The PCV valve is mounted on the driver-side valve cover. Remove & clean it with carb spray, or replace it.
What shape are the belts & hoses in?
Tom
Last edited by overlander63; 09-21-2007 at 06:56 PM. Reason: repaired defective manifold
Old 09-21-2007, 05:28 AM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
If it has been more than two years since it was done, deain and refill the coolant. It will eventually turn acidic, and cause things to go bad on you. A couple of gallons or so of coolant is cheap insurance.
While you are doing this, if you already haven't, it woulod be a good idea to \change the thermostat and gasket. Check the end of the fan clutch to make sure it doesn't have oil oozing from the center, and replace both fuel filters if you haven't gone it recently. Also, check the level of gear lube in the differential, and make sure you grease everything with a grease fitting. Some fittings are in places you wouldn't think to look.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 09-21-2007, 05:35 AM   #4
klattu
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 854
Hit or Miss
Remember to set your Dwell before you set the timing.
klattu is offline   Reply With Quote
Old 09-21-2007, 06:01 AM   #5
overlander63
Images: 58
Electronic ignition does not have breaker points.
AIR#2611
Old 09-21-2007, 06:04 AM   #6
klattu
Liberator
klattu's Avatar
Images: 854
Oh....really?
Tell them to put 'em back in there....right now!
Old 09-21-2007, 06:10 AM   #7
overlander63
Images: 58
Oh....really?
I'll let 'em know...
AIR#2611
Old 09-21-2007, 08:06 PM   #8
jagcb750
jagcb750's Avatar
thanks to all that replied. I plan on getting at least some of the items done this weekend.
JaG
Old 09-27-2007, 03:01 PM   #9
jagcb750
jagcb750's Avatar
I changed the rotor, ignition module, condensor, and distributor cap and coils today before I went into work today. I read the sticky in this forum and got the ignition module and condensor the other day. Now I need to change the plug wires still and do the other basic type tune up items. I noticed that the wires I got which are not factory do not connect to the plastic ring-thing that sits on top of the distributor cap. I guess they should work o.k. other than that. They are, I believe, AC Delco. Anyway, awesome sticky, Thanks for the great pics.
JaG
Old 10-02-2007, 08:32 AM   #10
jagcb750
jagcb750's Avatar
Anybody know the part number for the original spark plug wires that snap into the retainer ring that sits on top of the distributor cap is?
Name:  retainer for plug wires.jpg
Here is a picture from the web of the ring.
JaG
Old 10-02-2007, 08:40 AM   #11
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i would think that any delco set would work?
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
Old 10-02-2007, 09:06 AM   #12
jagcb750
jagcb750's Avatar
I tried two different ac / delco sets and neither snaps onto this ring. I kinda like the idea of being able to lift the ring off and take the distributor cap off without having to mark my plug wires to work on changing a rotor or ignition module or capacitor.
JaG
Old 10-02-2007, 12:55 PM   #13
richinny
richinny's Avatar
maybe you could try bringing the ring to the place where you bought them and see what they say? my experience might be getting dated :-(
possibly a new ring might fit the new wire and the old distributor.
Ricky & (Ingrid)
Old 10-02-2007, 03:02 PM   #14
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Have I gloated lately about not having to worry about tune-ups ?
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
7.4l tune-up ALANSD Mechanics Corner - Engines, Transmission & More... 57 04-23-2008 11:38 AM
454 need a tune-up . . . or more! dinoburb Tow Vehicles 0 06-02-2006 07:02 PM
Generator tune up questions jaiman General Motorhome Topics 3 06-03-2004 06:37 AM
Tune up and... ALANSD Mechanics Corner - Engines, Transmission & More... 20 07-26-2002 04:55 PM
