Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-27-2004, 08:24 AM   #1
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Tranny Shift
My 1990 33 LY seems to be shifting incorrectly.
It was shifting okay until the other day when I took it to town to have it compounded and waxed.
I have been underneath the doghouse working on belts. Maybe I loosened something up inadvertantly.
It seems that the engine is revving up way to high before the transmission shifts to the next gear.
Is it possible that I have a vacuum leak somewhere?
What tells the transmission to shift in a timely manner?
I am assuming that the Tranny shifts when a ceratin level of vacuum is reached by the intake.
Please advise,
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 01-27-2004, 08:40 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
What tranny? Some are electronic, some vacuum/governor.
John
74Argosy24MH is offline   Reply With Quote
Old 01-27-2004, 08:41 AM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Ken,
Depending on the exact model there is a vacuum line that runs from the intake manifold to a valve on the side of the transmission. If the line is cracked or has come off you will have wonky shifting. I would start there. I have replaced most of my vacuum lines, but I have fewer lines than you do.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 01-27-2004, 08:45 AM   #4
smily
"Still Working"
smily's Avatar
Tranny type
Umm, only description I can give at this time is, Chevrolet, no overdrive, 454 engine and 1990 model.
All I know from here. I can ook at book later.
Smily
Ken Smillie
Old 01-27-2004, 08:47 AM   #5
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 215
Each year unique?
The only outside signal going to my tranny is (I think) an electric signal originating from a full throttle situation which precipitates a downshift. The Xeppelin has a fairly harsh shift it it shifts under a load.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 01-27-2004, 09:03 AM   #6
thenewkid64
Just a member
Images: 21
I know Fred (1985AIR345) had the same type of symptom. He had a bad vacuum line and he had the same type of problem.
Brett G
