Old 11-23-2016, 02:29 AM   #1
1988 34.5' Airstream 345
San Francisco , California
Tranny or tach problem
I'm confused and hope someone can advise.
I drove my 345 with 454 this weekend on a 4 hour trip.
Normally, she likes to run about 65mph while the engine is around 3,000 rpm.
Well, this trip I got up to cruising speed (65mph), and I see 4,000 rpm.
Odd that I didn't hear the noise because my dim recollection is that it gets significantly louder when going to 4,000. Instead, it sounded like 3,000 rpm.
Next thought, maybe my transmission is slipping the clutch. I pull off, drive at different speeds, etc. I note firm shifts in all 3 gears. Gas on/off with good response. Seems to not be slipping.
I drove for 4 hours this way. Temp pegged at 200 as normal
When I pulled over and shifted to neutral and park. Tach showed 2-2.2k rpm. High rpm on tach but didn't sound high.
I'm guessing that I've got some problem in my tachometer, but don't want to get my hopes up as the alternative is tranny work (ugh!).
nums is offline   Reply With Quote
Old 11-23-2016, 04:47 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Yes, sounds like you need a new
Old 11-23-2016, 05:06 AM   #3
Well Preserved
1993 21' Sovereign
Tach.
My tablet did something weird, and I had to go find a computer to post the last word...
Old 11-23-2016, 05:27 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
You would definitely hear the difference in the motor between running at 3000 vs 4000. That is, if youve driven your rig running at 3000rpm for any length of time in the past. Heres hoping and thinking its your tach.
mayco is offline   Reply With Quote
Old 11-23-2016, 05:45 AM   #5
Here is a listing on ebay for a Teleflex speedometer & tachometer. The speedometer is a boat speedometer so not useable in your motorhome but the tachometer should be a direct replacement for your existing tach. That is assuming your coach has the black and orange Teleflex gauges like the 86 and earlier coaches do.
It could also be a loose wire somewhere between the tach and the ignition coil.
Brd
Old 11-23-2016, 12:07 PM   #6
1977 31' Sovereign
Lynnwood , Washington
Before doing anything, confirm your concern with a manual tachometer.
- Nothing beats old school.
Tom
TomKirk is offline   Reply With Quote
Tach problems - Freightliner Chassis Mike1997 Mechanics Corner - Engines, Transmission & More... 8 02-13-2016 11:01 PM
2007 Toyota Tundra Tranny Problem SRW Tow Vehicles 23 07-10-2011 10:26 AM
Trans Temp & Tach installed bhayden Tow Vehicles 16 08-13-2007 12:25 PM
Tach repair Robfike Classic Motorhomes 6 01-11-2006 09:20 AM
Whats up with the tach? AccessMaster Airstream Motorhome Forums 12 01-27-2004 05:00 AM
