Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-19-2006, 07:32 PM   #1
noiva's Avatar
Chesapeake , Virginia
Images: 46
Question Towing Dolly With Electric Brakes
I'm seriously considering towing a small car using a dolly with my 370. Considering that the tag axle has electric trailer brakes, what would I need to know to run the wiring for the electric brakes on the dolly? Basically, I'm assuming that can be done , but how would I sync the two different sets of electric brakes? Separate brake controllers? One controller for both? Impossible? Help !
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 08-19-2006, 08:20 PM   #2
. , At Large
Tim, what kind of small car? If it is a car you can tow 4-down, you can get an Actibrake, or Brake Buddy to actuate all the brakes on the car. You could check into getting a tow dolly with surge brakes, that way you wouldn't have to wire anything else. I don't remember seeing any, but that doesn't mean they aren't made.
Old 08-19-2006, 08:30 PM   #3
noiva's Avatar
Images: 46
Terry,
Thanks. Master Tow was using surge brakes until this year, but I've noticed they're advertising electric brakes now. Demco has been electric. I'd prefer surge, but haven't located any. Not certain yet what I'll tow, but it will be FWD, and I really like the idea of just the rear wheels taking any wear. Also, the cost of a complete 4-down is much higher than a dolly due to the brake actuator cost. Those are the reasons I was attempting to determine how, or if, one would wire another electric brake with my tag axle set-up.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-19-2006, 08:53 PM   #4
. , At Large
I found a tow dolly with surge brakes--and it even has a torsion axle, like an Airstream! What more could you want? Here's the link:
http://www.crofttrailer.com/dolly.htm
Old 08-19-2006, 09:00 PM   #5
noiva's Avatar
Images: 46
Way to go, Terry ! I'll check this out first thing Monday morning. Hopefully, they're prices are similar to what I've found for the Master Tow dolly. Thanks so much.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 21 03-16-2020 07:50 PM
Towing Without Brakes? MattyBoy Brakes & Brake Controllers 31 09-17-2003 11:08 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 11:54 AM
