Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 12-21-2002, 12:20 PM   #1
Krazykraut
Guest
Profile:
Posts: n/a
Question Tow trailer wiring?
I need to wire up my trailer to tow behind my motorhome. The trailer is wired with three wires and a ground, turn and brake light on the same wire. The MH is wired for 4 wires and a ground. How can it be done?
Old 12-23-2002, 10:34 AM   #2
TRAPEZE
Profile:
Your local parts store will have a converter for this application. It is a flat black rectangular box with four wires going in, three coming out, with the ground being common. It will be clearly marked with the intended lights to be wired, and is easy for the “do it yourselfer”. Get the heavy-duty model, as these tend to burn out.
TRAPEZE is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
trailer side brake wiring diagram? munimula Brakes & Brake Controllers 5 10-27-2003 11:38 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 02:43 PM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 03:08 PM
Shakedown Run keylime 1959-69 Tradewind 5 12-05-2002 01:35 PM
