Old 02-17-2007, 03:02 PM   #1
1982 28' Airstream 280
Crowley , Texas
Send a message via Yahoo to Daddy4Bob
torque spec
Does anybody know the tourque spec for the thermostat housing on a 454?
'Can't never did nothin'!' - My Dad
Daddy4Bob is offline   Reply With Quote
Old 02-17-2007, 03:13 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Clymer says 30 ft-lbs.
Tom
Old 02-17-2007, 03:14 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
The book does not call for torque, snug tight.
(Excerp)
"Use a new gasket and sealer" Refill the cooling system and run the Engine, cheacking for leaks."
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 02-17-2007, 03:16 PM   #4
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Tom
Hmm opposing info, I've never torqued.. for what it's worth.
I'd use caution @ 30, talked to my Goodwrench Mechanic, "It'll snap it"
www.balrgn.com
Old 02-17-2007, 03:31 PM   #5
TomW's Avatar
1967 26' Overlander
Grade 8 bolts? Kind of doubt it.
But I torque with a calibrated arm too.
Tom
Old 02-17-2007, 06:42 PM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
They don't come with grade 8 do they?
Dave
Fyrzowt is offline   Reply With Quote
Old 02-17-2007, 06:49 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
"Torque is cheap" Not critical in this case. More important is that the mating surfaces are cleand and flat. Lap the housing on a piece of carborundum paper or use a file to make sure it's flat.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-18-2007, 11:55 AM   #8
1960 24' Tradewind
santa barbara , California
some fasteners such as a thermostat housing DO NOT need a torque wrench to be used .snug down the bolts so they are tight ,don't lean on the wrench
either .over tightening can break the housing "ears" off as well and distort the housing itself .The bolts are normally grade 5 ,they will have 3 equally spaced
marks on the bolt head ,grade 8 will have 6 marks .you don't need grade 8 bolts ,5 are typically the norm for intake manifold ,stat housing and many brackets on the engine as well .If you torque the bolts and one breaks off in the intake manifold ,it'll be big trouble and certainly ruin your day .
Scott
scottanlily is offline   Reply With Quote
Old 02-18-2007, 03:30 PM   #9
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you really feel the need to replace the bolts, you can put stainless fasteners in place of the zinc plated grade 5 ones. They are pretty cheap, and will resist corrosion.
What is the correct torque? IrishRover2 Wheels, Hubs & Bearings 4 11-19-2006 06:20 PM
manual wheel torque specifications.. safari05-25 Wheels, Hubs & Bearings 21 10-26-2006 11:40 PM
spec for alum sheet for airstream trailers Hopeful Brit 1970-79 Tradewind 2 06-30-2006 03:20 PM
torque converted dbyar Mechanics Corner - Engines, Transmission & More... 8 03-05-2003 05:21 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
